Sistema de luces automatico con VR
Hola buenas noches, tengo un problema:
Estoy haciendo un sistema de leds con reconocimiento de voz, y hoy he soldado el easyvr 3 y lo he acoplado a la arduino uno, ya tenia preparada la tabla de sonidos para meterla en el easy comander pero entonces me ha comenzado a dar errores: can not enter bootloader. (Tenia el jumper un Up), entonces he ido al IDE de Arduino para probar un test de EasyVR i no he podido subirlo a la placa porque me daba este error: Ha ocurrido un error mientras se enviaba el sketch (Con el jumper en SW).
Si lo pongo en HW me da este: avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Si lo pongo en PC:avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xbe
Y si lo uso en Up:avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x61
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x61
estoy 99% seguro de que no es un problema de soldadura, que me esta pasando? muchas gracias de Antemano
-Jordi
De casualidad estás usando los pines 0 y 1 (RX y TX) para algo?
Nop, tengo todos los pines sin usar
Parece un problema de energia. Alimenta con fuente externa tu arduino mas el shield VR.
surbyte:
Dios, muchisimas gracias porfin funciona como toca!
(No se si se puede pedir otra duda dentro del mismo post, si no se puede informarme, gracias!)
Bueno despues de arreglar el problema de los jumpers me he encontrado con otro, he subido la tabla de sonido a la placa y todos los commands, he generado el codigo con easy commander y lo he toqueteado un poco con el IDE para acostumbrarme al codigo y tal, he conseguido hacer bien los saltos de grupo y todo eso, pero hace poco he hecho algunos cambios en la tabla de sonido, la he subido igual que la otra, he generado codigo y cuando he hecho dobleclick me sale: Error: No se puede crear el programa, no tengo ni idea de por que pasa esto. Si intento abrir primero el ide i luego el codigo generado por Easyvr commander me sale esto:
Nombre fichero veus guai.ino no valido: ignorado
java.io.IOException: No se encontraron archivos de código válidos
	at processing.app.Sketch.listSketchFiles(Sketch.java:117)
	at processing.app.Sketch.<init>(Sketch.java:54)
	at processing.app.Editor.handleOpenInternal(Editor.java:1962)
	at processing.app.Editor.<init>(Editor.java:340)
	at processing.app.Base.handleOpen(Base.java:825)
	at processing.app.Base.handleOpen(Base.java:811)
	at processing.app.Base.handleOpen(Base.java:807)
	at processing.app.Base.handleOpen(Base.java:803)
	at processing.app.Base.handleOpenPrompt(Base.java:790)
	at processing.app.Editor$7.actionPerformed(Editor.java:547)
	at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
	at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
	at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
	at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
	at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
	at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
	at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
	at java.awt.Component.processMouseEvent(Component.java:6533)
	at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
	at java.awt.Component.processEvent(Component.java:6298)
	at java.awt.Container.processEvent(Container.java:2236)
	at java.awt.Component.dispatchEventImpl(Component.java:4889)
	at java.awt.Container.dispatchEventImpl(Container.java:2294)
	at java.awt.Component.dispatchEvent(Component.java:4711)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
	at java.awt.Container.dispatchEventImpl(Container.java:2280)
	at java.awt.Window.dispatchEventImpl(Window.java:2746)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
	at java.awt.EventQueue.access$500(EventQueue.java:97)
	at java.awt.EventQueue$3.run(EventQueue.java:709)
	at java.awt.EventQueue$3.run(EventQueue.java:703)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
	at java.awt.EventQueue$4.run(EventQueue.java:731)
	at java.awt.EventQueue$4.run(EventQueue.java:729)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Muchas gracias de antemano.
-Jordi
Algo parecido me ocurría con la IDE de Arduino.
Renombra el archivo, pero sin espacios y ni caracteres raros.
Lucario448:
Enserio muchas gracias, lo he canviado a una palabra y como la seda
Bueno chicos continúa mi odisea, con el transformador y el USB le continua faltando energia cuando pongo el shield, el led naranja no se enciende, solo cuando toco por abajo la placa que debe pasar algo de corriente, supongo que de ahí vienen todos mis problemas con el jumper pero no tengo ni idea de que puedo hacer. Muchas gracias
-Jordi
