Hey Arduino Community!
I am using an Arduino to compete in the Trinity College Robotics Competition. I am more familiar in standard C/C++ than wiring, so I decided to try my luck at installing and configuring the toolchain with the makefile. After an hour or so of modifying the Makefile to work with version 13 of the arduino software, I am using what is attached below.
It all works, and I can successfully run C++ apps on the arduino compiled through it. There is one... oddity, however. It seems as if the hex files created using my makefile are about 6x larger than the hex files created by the official Arduino IDE. I tested this out by creating a simple "sketch" in arduino IDE, then compiling the .cpp version in my toolchain. The exact same program compiled to a hex 6x larger than in the IDE. I am sure I just gave the compiler some incorrect flags, but I do not have enough experience to know which flags these are.
Thanks in advance for your help!
Output form loading on Arduino IDE
Binary sketch size: 1416 bytes (of a 14336 byte maximum
# ls -l
# 4002 Feb 18 16:58 sketch_090218a.hex
Output from loading through toolchain
avrdude: 8320 bytes of flash written
# ls -l
# 23426 Feb 18 17:24 main.hex
The Sketch:
void setup(){
void loop(){
Serial.println("test");
The "identical" CPP code:
#include "WProgram.h"
void setup(){
void loop(){
int main(void){
init();
setup();
for(;;)
loop();
return 0;
The Makefile:
# Arduino Makefile modified by Jordan Perr
# Original from Arduino.cc
# To Use this Makefile:
# -Copy this makefile into your project's directory
# -set BUILD_TARGETS all of your project's files to BUILD_TARGETS
# -set TARGET to your main target file's name. (eg. main for main.cpp)
# -set INSTALL_DIR to the location of your arduino installation
# -set PORT to the serial port you wish to download to. Use * as a wildcard
# -set UPLAOD_RATE to the baudrate of your Arduino
# make
# -builds into current directory, creating a TARGET.hex binary
# make upload
# -uses avrdude to download TARGET.hex to PORT
# make clean
# -removes all temp and binary files created during build
TARGET = main
BUILD_TARGETS = main.cpp
INSTALL_DIR = /Applications/arduino-0013
PORT = /dev/tty.usb*
UPLOAD_RATE = 19200
AVRDUDE_PROGRAMMER = stk500
MCU = atmega168
F_CPU = 16000000
## don't go below this line ##
ARDUINO = $(INSTALL_DIR)/hardware/cores/arduino
AVR_TOOLS_PATH = $(INSTALL_DIR)/hardware/tools/avr/bin
SRC = $(ARDUINO)/pins_arduino.c $(ARDUINO)/wiring.c \
$(ARDUINO)/wiring_analog.c $(ARDUINO)/wiring_digital.c \
$(ARDUINO)/wiring_pulse.c $(ARDUINO)/wiring_serial.c \
$(ARDUINO)/wiring_shift.c $(ARDUINO)/WInterrupts.c
CXXSRC = $(BUILD_TARGETS) $(ARDUINO)/HardwareSerial.cpp $(ARDUINO)/WMath.cpp $(ARDUINO)/Print.cpp
FORMAT = ihex
# Name of this Makefile (used for "make depend").
MAKEFILE = Makefile
# Debugging format.
# Native formats for AVR-GCC's -g are stabs [default], or dwarf-2.
# AVR (extended) COFF requires stabs, plus an avr-objcopy run.
DEBUG = stabs
OPT = s
# Place -D or -U options here
CDEFS = -DF_CPU=$(F_CPU)
CXXDEFS = -DF_CPU=$(F_CPU)
# Place -I options here
CINCS = -I$(ARDUINO)
CXXINCS = -I$(ARDUINO)
# Compiler flag to set the C Standard level.
# c89 - "ANSI" C
# gnu89 - c89 plus GCC extensions
# c99 - ISO C99 standard (not yet fully implemented)
# gnu99 - c99 plus GCC extensions
CSTANDARD = -std=gnu99
CDEBUG = -g$(DEBUG)
CWARN = -Wall -Wstrict-prototypes
CTUNING = -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
#CEXTRA = -Wa,-adhlns=$(<:.c=.lst)
CFLAGS = $(CDEBUG) $(CDEFS) $(CINCS) -O$(OPT) $(CWARN) $(CSTANDARD) $(CEXTRA)
CXXFLAGS = $(CDEFS) $(CINCS) -O$(OPT)
#ASFLAGS = -Wa,-adhlns=$(<:.S=.lst),-gstabs
LDFLAGS =
# Programming support using avrdude. Settings and variables.
AVRDUDE_PORT = $(PORT)
AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
AVRDUDE_FLAGS = -V -F \
-p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER) \
-b $(UPLOAD_RATE)
# Program settings
CC = avr-gcc
CXX = avr-gcc
OBJCOPY = avr-objcopy
OBJDUMP = avr-objdump
SIZE = avr-size
NM = avr-nm
AVRDUDE = avrdude
REMOVE = rm -f
MV = mv -f
# Define all object files.
OBJ = $(SRC:.c=.o) $(CXXSRC:.cpp=.o) $(ASRC:.S=.o)
# Define all listing files.
LST = $(ASRC:.S=.lst) $(CXXSRC:.cpp=.lst) $(SRC:.c=.lst)
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS)
ALL_CXXFLAGS = -mmcu=$(MCU) -I. $(CXXFLAGS)
ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
# Default target.
all: build
build: elf hex
elf: $(TARGET).elf
hex: $(TARGET).hex
eep: $(TARGET).eep
lss: $(TARGET).lss
sym: $(TARGET).sym
# Program the device.
upload: $(TARGET).hex
$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH)
# Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
COFFCONVERT=$(OBJCOPY) --debugging \
--change-section-address .data-0x800000 \
--change-section-address .bss-0x800000 \
--change-section-address .noinit-0x800000 \
--change-section-address .eeprom-0x810000
coff: $(TARGET).elf
$(COFFCONVERT) -O coff-avr $(TARGET).elf $(TARGET).cof
extcoff: $(TARGET).elf
$(COFFCONVERT) -O coff-ext-avr $(TARGET).elf $(TARGET).cof
.SUFFIXES: .elf .hex .eep .lss .sym
.elf.hex:
$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
.elf.eep:
-$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
--change-section-lma .eeprom=0 -O $(FORMAT) $< $@
# Create extended listing file from ELF output file.
.elf.lss:
$(OBJDUMP) -h -S $< > $@
# Create a symbol table from ELF output file.
.elf.sym:
$(NM) -n $< > $@
# Link: create ELF output file from object files.
$(TARGET).elf: $(OBJ)
$(CC) $(ALL_CFLAGS) $(OBJ) --output $@ $(LDFLAGS)
# Compile: create object files from C++ source files.
.cpp.o:
$(CXX) -c $(ALL_CXXFLAGS) $< -o $@
# Compile: create object files from C source files.
.c.o:
$(CC) -c $(ALL_CFLAGS) $< -o $@
# Compile: create assembler files from C source files.
.c.s:
$(CC) -S $(ALL_CFLAGS) $< -o $@
# Assemble: create object files from assembler source files.
.S.o:
$(CC) -c $(ALL_ASFLAGS) $< -o $@
# Target: clean project.
clean:
$(REMOVE) $(TARGET).hex $(TARGET).eep $(TARGET).cof $(TARGET).elf \
$(TARGET).map $(TARGET).sym $(TARGET).lss \
$(OBJ) $(LST) $(SRC:.c=.s) $(SRC:.c=.d) $(CXXSRC:.cpp=.s) $(CXXSRC:.cpp=.d)
depend:
if grep '^# DO NOT DELETE' $(MAKEFILE) >/dev/null; \
then \
sed -e '/^# DO NOT DELETE/,$d' $(MAKEFILE) > \
$(MAKEFILE).$$ && \
$(MV) $(MAKEFILE).$$ $(MAKEFILE); \
fi
echo '# DO NOT DELETE THIS LINE -- make depend depends on it.' \
>> $(MAKEFILE); \
$(CC) -M -mmcu=$(MCU) $(CDEFS) $(CINCS) $(SRC) $(ASRC) >> $(MAKEFILE)
.PHONY: all build elf hex eep lss sym program coff extcoff clean depend
