SIZE MATTERS!
I can't find the simplest darn thing regarding Arduino equipment - namely PHYSICAL SIZE :confused: .
Why are the physical dims NOT INCLUDED on any spec sheets??? :frowning:
PLEASE POINT me to where I can find the SIZE of each and every one of these buggers before I go buggers trying to locate it on some third-party review. :slight_smile:
Here is the Uno and Mega. Is this what you want?
I found what I was looking for on Wikipedia, here
But this seems kinda strange that there is NO LISTING FOR PHYSICAL SIZE on the tech sheets for these doo-dads.
On many projects, space is a serious PRIMARY consideration, and all the technical mumbo jumbo comes AFTER that most serious of all concerns.
You are sending a robot to Mars for example. What are your first concerns? Size & weight!
Did you look here: Arduino - Products
Clicking on the picture of each board takes one to a screen with "Tech Specs" including length, width, and weight, e.g.: https://store.arduino.cc/usa/arduino-uno-rev3
Also schematics and PCB design files are available under "Documentation".
GT_Mills:
But then again, the cost of making a custom board design is nearly invisible in your billion dollar budget. If size and weight are critical you would not use an off-the-shelf Arduino.
GT_Mills:
DECAF, I RECOMMEND DECAF...
GT_Mills:
List of Arduino boards and compatible systems - Wikipedia
What were you smoking?
Were you on Mars where there is no Google?
