Size of the Nano
Hi there,
Can anyone tell me the dimensions of the Arduino Nano? (in mm).
Especially the height (including all the pins mounted on the board)
Thanx!
M
http://arduino.cc/en/Main/ArduinoBoardNano shows the dimensions as 0.73" x 1.70". Then again, Gravitch's page at http://store.gravitech.us/arna30wiatp.html and the User Manual PDF linked from there shows 0.70” x 1.70”. Gravitech is the manufacturer.
Sparkfun's second picture of standard headers at Break Away Headers - Straight - PRT-00116 - SparkFun Electronics (click it to enlarge) shows they are a little over 1 cm high, then allow for the mini-USB connector and the ICSP header on the top of the board.
Hope that helps.
[edit]You can buy them without the pins if that helps. http://store.gravitech.us/arna30wiatn.html. No information on the vertical dimension though, sorry.[/edit]
[edit]Also in that class, I have one of the Oak Micros om328p Arduino clones. Arduino Playground - HomePage shows that the dimensions are even smaller than the Nano, at 1.4" x 0.7" (36mm x 18mm). An eyeball on a ruler shows the height including the pins is 15mm.[/edit]
