I send the array or the pointer? And all variables is uint8_t, so, it have 1byte, is right?
I wanna get the size of array inside the fuction, using only: function(array) How I can do this?
Sorry for my bad english and thank's again.
wizarcl:
An array is represented by a pointer to the first object in the array. When you pass an array as an argument to a function, you are passing a pointer to the first object in the array. The function doesn't care if it's simply a pointer to a single variable, or a collection of variables that constitute an array.
You can't, aside from defining the array to be one element more, and putting a "stop character" at the end. This is why you can do it for strings and strlen().
wizarcl:
But i dont understand why the sizeof inside function return 2 (2bytes) like you said.
so you're getting the size of the pointer (2 bytes)
Because i declared all like 1 byte.
Because a pointer doesn't contain actual data, it contains an address. If the pointer was only one byte wide, it could only contain 256 possible addresses. That means you could only have 256 bytes of memory (assuming the memory was byte addressable).
The size of a pointer in an ATmega328 (and many others) is 2 bytes. Think about it, you have 2kB of RAM, what is the fewest number of bytes you need to address the whole lot - the answer is 2.
sizeof() is not so much a function as it is a compile time calculation. If you call:
sizeof(values);
The compiler/pre-processor/whatever looks up the size of values. It is know that it is an array of 7 bytes, so sizeof() returns (7x1)=7.
Inside your function you call
sizeof(val);
So how big is it. Well it could be 7 bytes as before, but the compiler can't know that. What if you were for example to call:
byte newArray[100];
setvalues(newArray);
This time you have passed an array of 100 bytes, not 7. How can the compiler then work out what size it is supposed to be if it can change depending on when the function is called while the program is running.
As it doesn't know the size of the array, it defaults the returning the size of what you have declared which is really just
setValues(byte* val);
a byte* is a pointer, and how big is a pointer? 2 bytes. Why? see the first line of this post.
I believe I am right in saying that if you try this:
void setvalues(uint8_t val[7]){
ex_2 = sizeof(val); //But here, the function sizeof return 2. Why?
Then sizeof() would return 7 (I think). But then what happens if you pass a reference to an array of 2 bytes?
Thanks again guys…
I have one more question, i think, i can’t use:
#define pinModeAutomatic(p, m) pinModeAutomatic(p,m,sizeof(p))
because:
sketch_jul05a.ino:6:67: error: macro "pinModeAutomatic" passed 3 arguments, but takes just 2
sketch_jul05a.ino:16:67: error: macro "pinModeAutomatic" passed 3 arguments, but takes just 2
sketch_jul05a:6: error: variable or field 'pinModeAutomatic' declared void
sketch_jul05a.ino: In function 'void setup()':
sketch_jul05a:8: error: 'pinModeAutomatic' was not declared in this scope
sketch_jul05a.ino: At global scope:
sketch_jul05a:16: error: function definition does not declare parameters
You're right, it doesn't work, forgot #define and function had to be slightly different names.
(Again, I recommend you DONT declare variable names with ALLCAPITALLETTERS as they should be left to #define constants. If you aren't careful you could find yourself declaring a variable whose name is the same as an existing #define)
