On the Arduino Nano RP2040 Connect, whenever I run a sketch using the sizeof() function, the Nano starts blinking the orange light with 3 long pulses, then 3 short pulses, repeating. On Windows, the COM port is no longer recognized, and I sometimes get a notification saying something like "The USB device has malfunctioned, try plugging it in again". Oddly enough, the sketch with the sizeof() worked at some point on the Connect, but recently started throwing this weird error.
The fact that the function doesn't work is workaround-able, but the fact that every time I run a sketch with sizeof() I have to reset it in bootloader mode is troubling. Here's an example sketch below:
int test [4] = {5, 4, 3, 2};
for (int k = 0; k < sizeof(test); k++) { //works just fine if I replace "sizeof(test)" with "4"
pinMode(test[k], OUTPUT);
Also, I haven't seen anything on the documentation about the orange light flashing in that pattern (3 long, 3 short pulses), so any info on that would be great too.
If you have your Preferences->Compiler warnings: turned up to 'All' you would have gotten this helpful warning:
/Users/john/Documents/Arduino/sketch_may19a/sketch_may19a.ino:7:19: warning: iteration 4 invokes undefined behavior [-Waggressive-loop-optimizations]
/Users/john/Documents/Arduino/sketch_may19a/sketch_may19a.ino:5:21: note: within this loop
for (int k = 0; k < sizeof(test); k++) //works just fine if I replace "sizeof(test)" with "4"
That's telling you that you are going beyond the limit of your array.
