Sizeof - Fundamental Data Type
Hi everyone, I'm trying to figure out what fundamental data type sizes are e.g.:
std::cout << "int:\t\t" << sizeof(int) << " bytes\n";
Is there some way of finding out the size of an int that an Arduino uses?
Couldn't find a more appropriate section so putting it in general. To mods: if you know a better place, please move.
https://www.arduino.cc/reference/en/language/variables/data-types/int/
Surely the obvious way would be to use the sizeof() macro
  Serial.println(sizeof(byte));
  Serial.println(sizeof(int));
  Serial.println(sizeof(long));
  Serial.println(sizeof(float));
  Serial.println(sizeof(double));
(Bizarrely, it's an operator, not a macro)
Well at least I didn't call it a function
Thanks guys, great info!
Considering that you posted
I am surprised that you did not try sizeof() in the first place. After all, the Arduino is programmed in C++
Well I'm still learning C++ but with C++ you have an OS with an operating system which has a terminal. Arduino doesn't have a terminal, so I was out of ideas about how to talk to it. I still don't know what your Serial.println(sizeof(double)); will do, but coupled with the link to the documentation I should be able to eventually figure this out. At least I now know that there is some kind of communication happening between the Arduino and the computer through the serial port and I would imagine there is something that will appear in the Tools->Serial Monitor window. I guess that's Arduino's terminal. Reading the documentation now.
Nope.
You were almost calling it (sizeof(int)) a function because of having a pair of parentheses accepting its argument?
byte y = sizeof(int);
size_t serialSize = sizeof Serial;
Parentheses?
What parentheses? :wink:
1. In Arduino UNO where we have 8-bit MCU, the size of int data type is 2-byte:
byte n = sizeof(int);   // n = 2 bytes = 16-bit
Serial.println(n, DEC);    //shows: 2 ==> 2 bytes = 16-bit
2. In Arduino DUE where we have 32-bit MCU, the size of int data type is 4-byte.
byte n = sizeof(int);   // n = 4 bytes = 32-bit
Serial.println(n, DEC);    //shows: 4 ==> 4 bytes = 32-bit
Exactly! The Serial Monitor is the Arduino's Terminal(Fig-1, Fig-2)
Figure-1:
Figure-2:
'(' is called "Opening Parenthesis" and ')' is called "Closing Parenthesis". "( )" is called "Pair of Parentheses". I am a non-native and that's all I know.
Sorry, I of course just meant OS with a terminal. Typed OS twice.
I was simply pointing-out the absence of any parentheses in the (correct) example I gave; nothing to do with spelling.
Still nope
This is the style (sizeof int) I prefer to use; because, sizeof (being a keyword) is not a function name - it is an operator which you have also mentioned.
But
size_t sizeInt = sizeof int;
doesn't compile, so why would you prefer that?
Just now discovered that for the sizeof operator to work on a keyword like int, the argument should be within ( ). For example:
For arguments other than keyword, sizeof works on both styles -- with and without ( ).
