sizeof() utility problem
Hello,
I am having a problem with the sizeof() utility.
The reference gives this program as an example:
char myStr[] = "this is a test";
int i;
void setup(){
for (i = 0; i < sizeof(myStr) - 1; i++){
Serial.print(i, DEC);
Serial.print(" = ");
Serial.println(myStr*, BYTE);*
    [/quote]
    This program works with no problem.
    My problem with this example is that myStr is a global variable. If I try to pass a variable to a function where I need to use sizeof(), as in:
    > int i;
    > void setup(){
    > Serial.begin(9600);
    > void printWord(char myStr[])
    > void loop()
    > * char myStr[] = "this is a test";*
    > * printWord(myStr);*
    > [/quote]
    > It simply sends 't' (the first character) over and over.
    > How do I pass variables in such a way that sizeof still works?
    > for the record it works if I set the for loop to i<14, and it works if I declare myStr within printWord.
You want "strlen()" instead of sizeof. sizeof is a compile-time thing, and only works for pieces of data whose size is know at the time of compilation, rather than at runtime.
You can't. Variables do not contain any extra information to allow their size, type, etc. to be determined at run time. That's a fundamental limitation of C/C++ implementation.
The way to do what you want is to pass the size in addition to the string.
void printWord(char myStr[], int strLen)
 int i;
 for (i = 0; i < strLen - 1; i++){
   Serial.println(myStr[i], BYTE);
The more common way of handling this is to exploit the fact that a string is usually "null-terminated", meaning that the last character of the string is followed by a byte with a zero value.
 int i;
 for (i = 0; myStr[i] != '\0'; i++){
As a side note, sizeof is not a utility. Although it is usually used in a manner that suggests it is a function, it is actually a compile time operator. No parentheses are required with sizeof although they are frequently used. For example, the following code is perfectly legal.
int x;
int y = sizeof x;
That usage suggests the actual nature of the sizeof operator.
Thanks for the replies, this is a very responsive forum!
strlen() works great.
Good ideas Don, I always forget that the second argument in a for loop can be any condition at all. Very useful.
