I'm not much of a C programmer, so please bear with me... I had a question concerning these two functions... I know one returns the size of the actual variable, in the case of a string, it's the number of characters plus the null ending, but something seems weird to me, since when I ask for a sizeof a char array I passed to a function, it faithfully says 2. strlen reports properly. I think I'm missing something very fundamental. Can somebody explain/direct? See enclosed code and results. This isn't my exact code of course, but it reproduces the same results.
Thank you!
Andy
So I guess what I need to do here is be able to pass a string of various lengths to that function, but now I see it's giving me all sorts of grief because I have no idea what I'm doing with pointers and so forth - For example, say I want to implement a FOR loop to output the strings "cheezburger1,cheezburger2,cheezburger3,cheezburger4" to my function.. OK I know these are all the same length, but maybe I also want to output different lengths too... It works great when I'm just sending hard coded text, but how do I manipulate this?
Basically, I just need to have something akin to the 'serial.print' and be able to pass data in to it like that.. whatever I want.....uh oh... does this mean I need to learn how to write a class??
OK - Here's what I'm actually doing... I have a bunch of custom dot matrix shift register lighting blah blah.. It's a character display, 128 bulbs in four groupings of 32. I have all of that stuff worked out, the hardware is gorgeous. It's the fact that I learned BASIC 25 years ago..and I'm 'tarded.
In my actual program, if I use
writeTime("ABCD");
writeTime("1234");
everything is great. Problem is, how do I put incrementing numeric values in there? In other words... say... turn HOURS in to a string, MINUTES in to a string, then squash them together and output a 4 byte string to this function? I know for strictly numbers I could just pass a numeric value and this would be easy, but I kinda need to talk to this function like LCD or Serial to have it work the way I want it... and I have the sinking feeling that I'm going about it all wrong.
void writeTime (char letters[]){
//This is only part of the program
int X;
Serial.println("Size of letters is " + String(strlen(letters)));
if (debug == true){ Serial.println ("Deconstructing " + String(letters));}
digitalWrite(latchPin, LOW); // Drop the latch.
for (int X = 0; X < strlen(letters); X ++){
// Now, map ASCII values to our fonts.
byte A = (selectChar(letters[X]));
// Now start outputting to the shift registers
shiftOut(dataPin, clockPin, LSBFIRST, font[A][3]);
shiftOut(dataPin, clockPin, LSBFIRST, font[A][2]);
shiftOut(dataPin, clockPin, LSBFIRST, font[A][1]);
shiftOut(dataPin, clockPin, LSBFIRST, font[A][0]);
digitalWrite(latchPin, HIGH); // Raise the latch.
void func(char* string) {
Serial.println(string);
int hours, minutes;
char buf[64]; // create a place for the string to go
sprintf(buf, "%2d:%2d", hours, minutes);
// buf now contains hours and minutes with a colon in between, each at least 2 digits long with leading 0 if necessary
func(buf);
Seems like I may have some luck with this... though it seems like I'm getting a leading "null" instead of a leading "0"
I think we're looking for sprintf(buf, "%02d:%02d", hours, minutes);
HOWEVER... that was not the breakthrough.
void writeTime2 (char* letters){
THAT was. That little * - It used to be void writeTime2 (char letters[]){
PS, sprintf is awesome. Why does Arduino make no mention of this?
Sorry, you're right. Although you really should say "space" rather than "null" because a null means a binary 0 while a space is 32, and there's ASCII 0 which is different.
really? I thought there was no difference between the two, just different forms of the same thing.
It's nice. If you're annoyed about having to make a buffer if you're just going to print it to the serial or an lcd or something you can use fprintf without a character buffer easily: avr-libc: <stdio.h>: Standard IO facilities
