sizing an array with a variable
it looks like I can't set the size of an array using a variable, example this code does not work
int qtyOutputs = 3;
float outPuts[qtyOutputs];
but this code does
int qtyOutputs = 3;
float outPuts[3];
is this a bug in arduino, an error I am making, or a feature I don't understand? thanks for any help. I could probably use define but that is always scary. easy to mess something up there.
it looks like I can’t set the size of an array using a variable
Depends on where you try to do it.
If the array is global, the variable needs to be const.
No.
an error I am making, or a feature I don’t understand?
It’s one or the other.
