Sk-yd60 Touch Led Lamp
Hi. This is nothing about Arduino, and please moderators to replace this post if you need.
I have 2 LED lights sk-yd60 on touch sensor, which one of them is hand smashed by other person, and now not working good.
Functions (one button) :
  • Fast touch: On/Off
  • Long holding: Dims to bright/Dims to dark.
The problem is that light work, but it Dim by itself and switch On/Of by itself. Also when you hard shake it/smash it then change light. It seems some sensor problem.
It has only 1 spring which attached to sensor. So, on which principle that light work? I tried stretch/outstretch spring, sometimes work on touch and sometimes not. But it is weird that only have plastic for touch fingers, which plastic go directly on that spring!? Is there some trick, maybe foil can help?
I have 1 other same light which working fine, and sensitive on little touch. It is better that I will not open, because I know that will stop work then.
Why repair this? Because it is very durable battery, it's working 5 nights without charge.
It seems some problem with ground.
What I found now is that when I hold any CHIP, or (+) and (-) pins with fingers at same time when tap or hold spring, it works normally.
What is that?
