skee ball
I'm looking to build a skee ball machine for my basement. I'm not sure what board I need to use for the scoreboard. I'm looking for something basic. I plan on using either a micro switch or sensor switch for the holes the balls will go through. Each hole will be a different point value, so the board will have to add them up for a total. I'm thinking basic digital numbers. It would also have to reset after so many balls pass through. any thoughts on the subject would be greatly appreciated. Thank you
Moved your topic to a mores suitable section.
You may want to READ THIS for future reference. It will help you get the best out of the forum.
Bob.
HI, Welcome to the forum.
You will have to explain what "skee ball" is. What hardware does it use.
Thanks.. Tom... :)
