Sketch does not run on arduino pro mini clone when starting with external power
I have one of those cheap arduino pro mini clones off ebay and I’m having trouble getting it to work with external power.
I have a RFID reader (over i2c) and a rotary encoder, and it’s supposed to send data over bluetooth that Processing can pick up.
But the sketch, or the RFIDreader doesn’t start when i plug in the external power supply (5V connected to RAWpin)
If I plug in the USBcable, the sketch and the reader starts, and i can unplug the cable and everything runs smooth over bluetooth.
But how can I make it run without plugging the USB-cable in and out? Some issues with the reset?
I’ve seen people having this trouble, but havent found a solution
Tried to wire Rx to ground with a 10k resistor, but it didn’t work either
Thanks!
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_PN532.h>
#include <Encoder.h>
// If using the breakout with SPI, define the pins for SPI communication.
#define PN532_SCK  (2)
#define PN532_MOSI (3)
#define PN532_SS   (4)
#define PN532_MISO (5)
int state=0;
// If using the breakout or shield with I2C, define just the pins connected
// to the IRQ and reset lines.  Use the values below (2, 3) for the shield!
#define PN532_IRQ   (5)
#define PN532_RESET (6)  // Not connected by default on the NFC Shield
int pushButton = 4;
Encoder myEnc(2, 3);
long oldPosition  = -999;
// Uncomment just _one_ line below depending on how your breakout or shield
// is connected to the Arduino:
// Use this line for a breakout with a SPI connection:
//Adafruit_PN532 nfc(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS);
// Use this line for a breakout with a hardware SPI connection.  Note that
// the PN532 SCK, MOSI, and MISO pins need to be connected to the Arduino's
// hardware SPI SCK, MOSI, and MISO pins.  On an Arduino Uno these are
// SCK = 13, MOSI = 11, MISO = 12.  The SS line can be any digital IO pin.
//Adafruit_PN532 nfc(PN532_SS);
// Or use this line for a breakout or shield with an I2C connection:
Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);
void setup(void) {
  Serial.println("Hello!");
  pinMode(pushButton, INPUT_PULLUP);
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  // Set the max number of retry attempts to read from a card
  // This prevents us from waiting forever for a card, which is
  // the default behaviour of the PN532.
  nfc.setPassiveActivationRetries(0xFF);
  // configure board to read RFID tags
  nfc.SAMConfig();
  Serial.println("Waiting for an ISO14443A card");
void loop(void) {
    long newPosition = myEnc.read();
  if (newPosition != oldPosition) {
    if (newPosition < oldPosition){
    Serial.println("volDown");
    if (newPosition > oldPosition){
      Serial.println("volUp");
    oldPosition = newPosition;
   //Serial.println(newPosition);
  int buttonState = digitalRead(pushButton);
  // print out the state of the button:
  delay(1);        // delay in between reads for stability
  if (buttonState==0){
    Serial.println(F("Knapp"));
    delay(50);
  boolean success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };	// Buffer to store the returned UID
  uint8_t uidLength;				// Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength);
  if (success) {
  if (state==0){
    for (uint8_t i=0; i < uidLength; i++)
      Serial.print("0x");Serial.print(uid[i], HEX);
  state=1;
  else if (state==1)
    // PN532 probably timed out waiting for a card
    Serial.println("Pause");
    state=0;
Isolated the problem to the RFID reader. There's something going on in the setup
Blink sketch and rotary encoder library works fine on its own.
