Sketch does not update LCD properly - Solved
I made the sketch below for a GPS clock.
It runs correctly on the Serial Monitor.
However, at the LCD display the seconds do not change smoothly. They sometimes stand still for a couple of seconds, then catch-up correctly.
As in this example with a number per second:
10 11 12 12 14 15 16 16 16 19 20
where it should be:
10 11 12 13 14 15 16 17 18 19 20
So it looks like the program is not updating the display every second, but I can't see why.
Any hint is highly appreciated.
Best regards,
Niels
#include <TinyGPSPlus.h> // by Mikal Hart
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //Arduino pins for communication
static const int RxPin = 8, TxPin = 9; // TxPin bruges ikke i dette projekt
static const uint32_t GPSBaud = 9600;
// Erklæring af tider og strenge
int day, month, year, hour, minute, second;
String dateStr, dayStr, monthStr, yearStr;
String timeStr, hourStr, minuteStr, secondStr;
// The TinyGPSPlus object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RxPin, TxPin);
// For stats that happen every 5 seconds
unsigned long last = 0UL;
void setup() {                  delay(3000);
	ss.begin(GPSBaud);
  // Display setup
  lcd.begin(16, 2); //start LCDlibrary and set display size
  lcd.clear(); // Position (0,0)
  //  Display test
  //  lcd.print("1. linje");
  //  lcd.setCursor(0,1);   // position 0-15, linje 0-1
  //  lcd.print("2. linje");
  //  lcd.clear();
	// Dispatch incoming characters
	while (ss.available() > 0) {
		gps.encode(ss.read());
	if (gps.date.isUpdated()) {
    year = gps.date.year();
    month = gps.date.month();
    day = gps.date.day();
  if (gps.time.isUpdated()) {
    hour = gps.time.hour();
    minute = gps.time.minute();
    second = gps.time.second();
  // Konvertering af tider til strenge
  dayStr = String(day);
  monthStr = String(month);
  yearStr = String(year);
  hourStr = String(hour);
  minuteStr = String(minute);
  secondStr = String(second);
  // Minimum 2 cifre i værdi
  if (day < 10) { dayStr = '0'+ dayStr; }
  if (month < 10) { monthStr = ' ' + monthStr; }
  if (hour < 10) { hourStr = '0' + hourStr; }
  if (minute < 10) { minuteStr = '0' + minuteStr; }
  if (second < 10) { secondStr = '0' + secondStr; }
  // Færdiggør display-strenge
  dateStr = dayStr + " " + monthStr + " " + yearStr;
  timeStr = hourStr + ":" + minuteStr + ":" + secondStr;
  // Til monitor
  Serial.println( dateStr + "   " + timeStr );
  // To LCD. Cleared in setup.
  lcd.setCursor(4,0); // (position,line)
  lcd.print(timeStr);
  lcd.setCursor(3,1);
  lcd.print(dateStr);
I think you are updating the LCD too frequently. Is it updated each time loop() runs, even if the time has not changed.
Please always click Auto-Format in the IDE menu before you post your code, that makes it easier to spot errors like { or } in the wrong place.
TinyGPSPlus gps;
  ss.begin(GPSBaud);
  // Display setup
  //  Display test
  //  lcd.clear();
  if (ss.available() > 0) {
    // Til monitor
    lcd.print(timeStr);
    lcd.setCursor(3,1);
    lcd.print(dateStr);
Now let's make it shorter and more efficient
TinyGPSPlus gps;
  ss.begin(GPSBaud);
  // Display setup
  //  Display test
  //  lcd.clear();
    char dateStr[17];
    char timeStr[17];
    sprintf(dateStr, "%02d %02d %02d", gps.date.day(), gps.date.month(), gps.date.year());
    sprintf(timeStr, "%02d:%02d:%02d", gps.date.hour(), gps.date.minute(), gps.date.second());
    // Til monitor
    Serial.print( dateStr );
    Serial.print("   ");
    Serial.println( timeStr );
    lcd.print(timeStr);
    lcd.setCursor(3,1);
    lcd.print(dateStr);
@PaulRB
Thank you for your reply.
Yes.
Now, when I had only seen the mail notification about your reply, I changed to:
if (timeStr != oldTimeStr) {  //Avoid unneeded display update
    lcd.setCursor(4, 0);  // (position,line)
    lcd.print(timeStr);
    lcd.setCursor(3, 1);
    lcd.print(dateStr);
    oldTimeStr = timeStr;
and that shows that you are right.
you post your code
Ok. I was not aware of that function.
I need more time to study the other suggestions you made.
Thank you.
However, I wonder why the changes on the display are slowed down by faster update.
