Sketch doesnt work without the pc??
I am at a totall los... The code below works fine when connected to the pc/IDE but when I power it with a USB cable outside (because of the GPS) it doesnt.
I have LED on pin7 that indicates whether the file has been created or not.
Inside it turns on, outside, no way.
I also tried powering the SD and GPS with an additional powersource. No luck
What can it be? It is a Nano
//#include <TinyGPS.h>
  #include <TinyGPS++.h>
  #include <SoftwareSerial.h>
  #include <SD.h> //load SD lib
  #include <SPI.h> // load SPI comm
  #include <Wire.h> // load Wire
  int chipSelect=5; //Set ChipSelect
  File myGpsData; //Variable for File
     This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
     It requires the use of SoftwareSerial, and assumes that you have a
     4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
  //static const int RXPin = 4, TXPin = 3;
  static const uint32_t GPSBaud = 9600;
  // The TinyGPS++ object
  TinyGPSPlus gps;
  // The serial connection to the GPS device
  SoftwareSerial ss(3, 4);
    //Serial.begin(115200);
    ss.begin(GPSBaud);
    SD.begin(chipSelect); //initialize SD Card
    pinMode(10, OUTPUT);
    pinMode(7, OUTPUT);
    //Serial.println(F("DeviceExample.ino"));
    //Serial.println(F("A simple demonstration of TinyGPS++ with an attached GPS module"));
   // Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
    //Serial.println(F("by Mikal Hart"));
    //Serial.println();
    // This sketch displays information every time a new sentence is correctly encoded.
    while (ss.available() > 0)
      if (gps.encode(ss.read()))
      displayInfo();
    if (millis() > 5000 && gps.charsProcessed() < 10)
      myGpsData.println(F("No GPS detected: check wiring."));
      while(true);
  //}//file open
  }//loop
  void displayInfo()
    myGpsData= SD.open("Gps.txt", FILE_WRITE);
    if (myGpsData){digitalWrite(7,HIGH);}
    myGpsData.print(F("Location: "));
    if (gps.location.isValid())
      myGpsData.print(gps.location.lat(), 6);
      myGpsData.print(F(","));
      myGpsData.print(gps.location.lng(), 6);
      myGpsData.print(F("INVALID"));
    myGpsData.print(F("  Date/Time: "));
    if (gps.date.isValid())
      myGpsData.print(gps.date.month());
      myGpsData.print(F("/"));
      myGpsData.print(gps.date.day());
      myGpsData.print(gps.date.year());
    myGpsData.print(F(" "));
    if (gps.time.isValid())
      if (gps.time.hour() < 10) Serial.print(F("0"));
      myGpsData.print(gps.time.hour());
      myGpsData.print(F(":"));
      if (gps.time.minute() < 10) Serial.print(F("0"));
      myGpsData.print(gps.time.minute());
      if (gps.time.second() < 10) Serial.print(F("0"));
      myGpsData.print(gps.time.second());
      myGpsData.print(F("."));
      if (gps.time.centisecond() < 10) Serial.print(F("0"));
      myGpsData.print(gps.time.centisecond());
    myGpsData.println();
    myGpsData.close();//close the file}
Never Mind.. Close it up.
CS Pin was just a hole misplaced..
(still wonder why it worked indoors. )
I need a pair of glasses.
Thanks for the update. We all make that sort of mistake.
...R
