Sketch exit status 1 expected '(' before 'unsigned
#define RELAY1 7 // On
#define RELAY2 8 // Off
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT22 // Temp
float h = 0, temperature = 0;
LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x27, 16, 2);
DHT dht(DHTPIN, DHTTYPE);
unsigned long previousMillis = 0; //Counter
const long interval = 1000; //Delay Time
dht.begin(); // initialize the sensor
lcd.init(); // initialize the lcd
lcd.backlight(); // open the backlight
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
float humi = dht.readHumidity(); // read humidity
float tempC = dht.readTemperature(true); // read temperature
lcd.clear();
lcd.setCursor(0, 0); // start to print at the first row
lcd.print("Temp: ");
lcd.print(tempC); // print the temperature
lcd.print((char)223); // print ° character
lcd.print("C");
if (temperature >= 24) { // Temp to HOT
digitalWrite(RELAY2, HIGH); // Triger Off Swith // Relay HIGH
digitalWrite(RELAY1, LOW); // Ideal
if
unsigned long currentMillis = millis(); // After a Few Sec move to relay LOW
(currentMillis - previousMillis >= interval
 (RELAY2 == HIGH)// Turn Relay to Low
 RELAY2 = LOW;
if (temperature >= 19) { // Temp to Low
digitalWrite(RELAY2, HIGH); // Triger On Switch
  digitalWrite(RELAY1, LOW); Ideal
  if
   (RELAY1 == HIGH) //Turn Relay to Low
   RELAY1 = LOW;
} else if (temperature < 20 && 23) { // Temp in Midle
digitalWrite(RELAY1, LOW); // Keep LOW
digitalWrite(RELAY2, LOW); // Keep LOW
Problem:exit status 1
expected '(' before 'unsigned'
It's to replace switch pad on pallet store
Thanks
Read the forum guidelines to see how to properly post code and information on how to get the most from this forum.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Did you forget something there?
Then a bit later you copied the same thing.
The if structure syntax is shown here.
j see now, thanks
