Sketch for making a Voice call with single push of a button - Not working...
Hi to all
i have this sketch
// libraries
#include <GSM.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess; // include a 'true' parameter for debug enabled
GSM_SMS sms;
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 6;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  // initialize serial communications
  Serial.println("SMS Messages Sender");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
  if(vcs.voiceCall("+12345678"))
          Serial.println("Call Established. Enter line to end");
          // Wait for some input from the line
          while(Serial.read()!='\n' && (vcs.getvoiceCallStatus()==TALKING));
          // And hang up
          vcs.hangCall();
        Serial.println("Call Finished");
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
But i get error while trying to upload it.
Please can anyone post a working sketch for making a voice call with press of a button (not with asking to enter a phone number etc…) only press of a button and then call
Thanks
This is compiling and uploading with no problem…can someone let me know if it will work
#include <GSM.h>
#include <GSM3CircularBuffer.h>
#include <GSM3MobileAccessProvider.h>
#include <GSM3MobileCellManagement.h>
#include <GSM3MobileClientProvider.h>
#include <GSM3MobileClientService.h>
#include <GSM3MobileDataNetworkProvider.h>
#include <GSM3MobileMockupProvider.h>
#include <GSM3MobileNetworkProvider.h>
#include <GSM3MobileNetworkRegistry.h>
#include <GSM3MobileServerProvider.h>
#include <GSM3MobileServerService.h>
#include <GSM3MobileSMSProvider.h>
#include <GSM3MobileVoiceProvider.h>
#include <GSM3ShieldV1.h>
#include <GSM3ShieldV1AccessProvider.h>
#include <GSM3ShieldV1BandManagement.h>
#include <GSM3ShieldV1BaseProvider.h>
#include <GSM3ShieldV1CellManagement.h>
#include <GSM3ShieldV1ClientProvider.h>
#include <GSM3ShieldV1DataNetworkProvider.h>
#include <GSM3ShieldV1DirectModemProvider.h>
#include <GSM3ShieldV1ModemCore.h>
#include <GSM3ShieldV1ModemVerification.h>
#include <GSM3ShieldV1MultiClientProvider.h>
#include <GSM3ShieldV1MultiServerProvider.h>
#include <GSM3ShieldV1PinManagement.h>
#include <GSM3ShieldV1ScanNetworks.h>
#include <GSM3ShieldV1ServerProvider.h>
#include <GSM3ShieldV1SMSProvider.h>
#include <GSM3ShieldV1VoiceProvider.h>
#include <GSM3SMSService.h>
#include <GSM3SoftSerial.h>
#include <GSM3VoiceCallService.h>
// libraries
#include <GSM.h>
GSM_SMS sms;
GSMVoiceCall vcs;
// set pin numbers:
  // connection state
  // Start GSM shield
  while(notConnected)
    // turn LED on:
  if(vcs.voiceCall("0887087696"))
          // And hang up
          vcs.hangCall();
Question 1 : will it work if i connect directly pin 2 to 5V with a button so by pressing it will make connection between pin2 and 5V or it is nessecary to connect pin2 to GND with 10K resistor and with switch to 5V
Question 2: as i understand arduino gsm shield and arduino uno are connected to upload our sketch. After we have uploaded our sketch, will the gsm shield work without the arduino uno i we power it up with the 5V (given normally from the arduino uno to the gsm shield) or they need to be connected together all the time to work.
Thanks
Hi:
Remember you have to add the voice circuit for the sketch to run, if you want to be able to hold a conversation.It is described here: http://arduino.cc/en/Main/ArduinoGSMShield Regarding the questions: 1-Use the resistor, otherwise when the switch is open the input would be a random value. 2.-The Shield has to be connected to the Arduino UNO. The Arduino runs the sketch and sends commands to the shield (such as "call", "hang", etc...)
