Apologies if this is a dumb question though I have am running a Nano with the below sketch to monitor temperature using a DS18B20 sensor and control two relays to either switch on a heat pad or switch on a fridge to control my beer fermentation temp.
After a couple days the Arduino freezes and I assume it is running out of memory, though I am not sure why.
Can some one please assist and tell me where my code is incorrect.
Temp and status of a pump input/output is also displayed.
Note: Ive removed the bitmap code for the images I display to keep the post under 9000 characters.
Cheers guys,
// THIS SKETCH CONTROLS 3 RELAYS FOR HEATING, COOLING AND PUMPING OF WORTH AND BEER
// INCLUDES ALL REQUIRED HUBS AND LIBRARIES BELOW
#include <Arduino.h>
#include <Wire.h>
#include <U8g2lib.h>
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 10 on the Arduino
#define ONE_WIRE_BUS 10
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// BELOW IS USED TO DEFINE THE SET POINT AND THE BUTTON USED TO CHANGE THESE POINT
int SetPoint = 20; // Initial temperature to start with
// BELOW USED FOR PUMP SWITCHING
//Pump Switch status inputs and Relay switching
int Pump = "-";
int pumpSwitch = 3;
int pumpRelay = 2; //Connects to Pump Relay
int val = 0; // push value from pin 3
int relayOn = 0; // Relay Status
int pushed = 0; // Push Status
#define Up_Key 6
#define Dn_Key 7
// CONFIGURE OUTPUTS FOR 240V SWITCHING RELAYS
int HEAT = 5; // pin 5 to run relay for heating
int COOL = 4; // pin 4 to run relay for cooling
// THE BELOW WORKS FOR A SH1106 OLED DISPLAY ON THE U8G2 LIBRARY
// THIS SETS UP THE OLED TO OPERATE CORRECTLY
U8G2_SH1106_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
// THE XBM FILE GOES BELOW - MUST KNOW DEMENSIONS!
#define newhops_width 63
#define newhops_height 64
static const unsigned char newhops_bits[] PROGMEM = {
#define happyhop_width 128
#define happyhop_height 64
static const unsigned char happyhop_bits[]PROGMEM = {
float temperature; //NOT SURE WHAT THESE ARE FOR YET
char temperatureString[6] = "-"; //NOT SURE WHAT THESE ARE FOR YET
void draw1(void) {
// graphic commands to redraw the complete screen should be placed here
u8g2.drawXBMP( 0, 0, newhops_width, newhops_height, newhops_bits); // THESE LINES CALL UPON THE SIZING AT THE TOP OF THE BITMAP CODING.
u8g2.setFont(u8g2_font_crox2tb_tr);
u8g2.drawStr(27, 10, "BREW STATS");
u8g2.setFont(u8g2_font_ncenB08_tr);
u8g2.drawStr(42, 25, "TEMP =");
u8g2.drawStr(90, 25, temperatureString);
u8g2.setFont(u8g2_font_courB08_tf);
u8g2.drawStr(106, 22, "o");
u8g2.drawStr(113, 25, "C");
u8g2.drawStr(42, 42, "SET =");
u8g2.setCursor(90, 42);
u8g2.print(SetPoint);
u8g2.drawStr(106, 39, "o");
u8g2.drawStr(113, 42, "C");
u8g2.drawStr(42, 59, "PUMP =");
u8g2.drawStr(90, 58, Pump);
void draw2(void) {
u8g2.drawXBMP( 0, 0, happyhop_width, happyhop_height, happyhop_bits);
void setup(void) {
//configure pump operation input with use of pull up resistor and output to relay
pinMode(pumpSwitch, INPUT_PULLUP);
pinMode(pumpRelay, OUTPUT);
//cofigures outputs to relays
pinMode(HEAT, OUTPUT);
pinMode(COOL, OUTPUT);
//configures the below pins as inputs and enables the internal pull-up resistor
pinMode(7, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
// Define use of Internal LED
pinMode(LED_BUILTIN, OUTPUT);
// SETS UP THE BUTTON INPUTS
pinMode(Up_Key, INPUT);
pinMode(Dn_Key, INPUT);
//Pull up for setpoint keys
digitalWrite(Up_Key, HIGH);
digitalWrite(Dn_Key, HIGH);
sensors.begin(); //Start Sensors
// STARTS THE OLED AND DISPLAY
u8g2.begin();
u8g2.firstPage();
do {
u8g2.setFont(u8g2_font_ncenB14_tr);
u8g2.drawStr(47, 20, "IT'S");
u8g2.drawStr(35, 38, "BREW");
u8g2.drawStr(36, 56, "TIME!");
} while ( u8g2.nextPage() );
delay(3000);
u8g2.firstPage();
do {
draw2();
delay(4000);
u8g2.firstPage();
do {
u8g2.drawStr(42, 20, "I'M");
u8g2.drawStr(10, 38, "HOPPING");
u8g2.drawStr(35, 56, "MAD");
delay(3000);
void loop(void) {
// THIS STARTS THE PICTURE LOOP
u8g2.firstPage();
do {
draw1();
// UPDATES THE TEMPERATURES
// Read Temperature
temperature = sensors.getTempCByIndex(0);
// Update the sensor readings
sensors.requestTemperatures();
dtostrf(temperature, 2, 0, temperatureString);
//read the pushbutton values into a variable
int sensorVal1 = digitalRead(7);
int sensorVal2 = digitalRead(6);
if (sensorVal1 == LOW) {
SetPoint++;
if (sensorVal2 == LOW) {
SetPoint--;
// Controls LED Output and switiches relays on or off with a 1 Degree Celcius Hysterisis
if (temperature < SetPoint + 1) {
Serial.println("Relay on!");
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(HEAT, HIGH);
else {
digitalWrite(HEAT, LOW);
if (temperature > SetPoint) {
Serial.println("Relay OFF");
digitalWrite(LED_BUILTIN, LOW);
digitalWrite(COOL, HIGH);
else {
digitalWrite(COOL, LOW);
Serial.print(temperatureString);
Serial.println(" Deg C");
Serial.print(SetPoint);
Serial.print(Pump);
// CONTROLS THE PUMP RELAY
val = digitalRead(pumpSwitch);
if(val == HIGH && relayOn == LOW) {
pushed = 1-pushed;
delay(100);
relayOn = val;
if(pushed == HIGH) {
digitalWrite(pumpRelay, LOW);
Pump = "OFF";
}else{
digitalWrite(pumpRelay, HIGH);
Pump = "ON";
