Sketch für WS2812B 5050 SMD 256 RGBIC Strip anpassen ?
Hallo zsm,
Ich nutze ein ATmega328-Board von AZDelivery: B01MDJA464 in der Amazon Suche eingeben , dachte das macht das Thema etwas kürzer lol und dieses RGBIC Strip: B0BTVBTHQ5
Das Board und das Stip wird bei mir als Ambilight Ersatz genutzt.
Auf das Board habe ich dieses Sketch hochgeladen :
#include "FastLED.h"
   ANDROID AMBILIGHT APPLICATION ARDUINO SKETCH
   set following values to your needs
#define INITIAL_LED_TEST_ENABLED true
#define INITIAL_LED_TEST_BRIGHTNESS 16  // 0..255
#define INITIAL_LED_TEST_TIME_MS 250  // 10..
// Number of leds in your strip.
// Tested with 500 leds and is fine (despite the warning)
// We will use a maximum of 300
#define MAX_LEDS 216
// type of your led controller, possible values, see below
#define LED_TYPE WS2812B
// 3 wire (pwm): NEOPIXEL BTM1829 TM1812 TM1809 TM1804 TM1803 UCS1903 UCS1903B UCS1904 UCS2903 WS2812 WS2852
//               S2812B SK6812 SK6822 APA106 PL9823 WS2811 WS2813 APA104 WS2811_40 GW6205 GW6205_40 LPD1886 LPD1886_8BIT
// 4 wire (spi): LPD8806 WS2801 WS2803 SM16716 P9813 APA102 SK9822 DOTSTAR
// For 3 wire led stripes line Neopixel/Ws2812, which have a data line, ground, and power, you just need to define DATA_PIN.
// For led chipsets that are SPI based (four wires - data, clock, ground, and power), both defines DATA_PIN and CLOCK_PIN are needed
// DATA_PIN, or DATA_PIN, CLOCK_PIN
#define LED_PINS 6        // 3 wire leds
//#define LED_PINS 6, 13  // 4 wire leds
#define COLOR_ORDER GRB  // colororder of the stripe, set RGB in hyperion
#define OFF_TIMEOUT 8000    // ms to switch off after no data was received, set 0 to deactivate
#define BRIGHTNESS 255                      // maximum brightness 0-255
#define DITHER_MODE BINARY_DITHER           // BINARY_DITHER or DISABLE_DITHER
#define COLOR_TEMPERATURE CRGB(255,255,255) // RGB value describing the color temperature
#define COLOR_CORRECTION  TypicalLEDStrip   // predefined fastled color correction
//#define COLOR_CORRECTION  CRGB(255,255,255) // or RGB value describing the color correction
// Baudrate, higher rate allows faster refresh rate and more LEDs
#define BAUD_RATE 115200      // use 115200 for ftdi based boards
   no user changes needed
// Adalight sends a "Magic Word" before sending the pixel data
uint8_t prefix[] = {'A', 'd', 'a'}, hi, lo, chk, i;
unsigned long endTime;
// Define the array of leds
CRGB leds[MAX_LEDS];
// set color to all leds
void showColor(const CRGB& led) {
  #if MAX_LEDS > 1
  LEDS.showColor(led);
  #endif
// switch of leds
void switchOff() {
  #if MAX_LEDS > 1
  memset(leds, 0, MAX_LEDS * sizeof(struct CRGB));
  FastLED.show();
  #endif
// function to check if serial data is available
// if timeout occured leds switch of, if configured
bool checkIncommingData() {
  boolean dataAvailable = true;
  while (!Serial.available()) {
    if ( OFF_TIMEOUT > 0 && endTime < millis()) {
      switchOff();
      dataAvailable = false;
      endTime = millis() + OFF_TIMEOUT;
  return dataAvailable;
// main function that setups and runs the code
  Serial.begin(BAUD_RATE);
  Serial.print("Ada\n"); // Send "Magic Word" string to host
  int ledCount = MAX_LEDS;
  #if MAX_LEDS > 1
    FastLED.addLeds<LED_TYPE, LED_PINS, COLOR_ORDER>(leds, ledCount);
  #endif
  // color adjustments
  FastLED.setBrightness ( BRIGHTNESS );
  FastLED.setTemperature( COLOR_TEMPERATURE );
  FastLED.setCorrection ( COLOR_CORRECTION );
  FastLED.setDither     ( DITHER_MODE );
  // initial RGB flash
  #if INITIAL_LED_TEST_ENABLED == true
  for (int v=0;v<INITIAL_LED_TEST_BRIGHTNESS;v++)
    showColor(CRGB(255,0,0));
    delay(INITIAL_LED_TEST_TIME_MS/2/INITIAL_LED_TEST_BRIGHTNESS);
    showColor(CRGB(0,255,0));
    showColor(CRGB(0,0,255));
  #endif
  showColor(CRGB(0, 0, 0));
  boolean transmissionSuccess;
  unsigned long sum_r, sum_g, sum_b;
  // loop() is avoided as even that small bit of function overhead
  // has a measurable impact on this code's overall throughput.
  for(;;) {
    // wait for first byte of Magic Word
    for (i = 0; i < sizeof prefix; ++i) {
      // If next byte is not in Magic Word, the start over
      if (!checkIncommingData() || prefix[i] != Serial.read()) {
        i = 0;
    // Hi, Lo, Checksum
    if (!checkIncommingData()) continue;
    hi = Serial.read();
    lo = Serial.read();
    chk = Serial.read();
    // if checksum does not match go back to wait
    if (chk != (hi ^ lo ^ 0x55)) continue;
    int num_leds = min ( MAX_LEDS, (hi<<8) + lo + 1 );
	memset(leds, 0, num_leds * sizeof(struct CRGB));
    transmissionSuccess = true;
    sum_r = 0;
    sum_g = 0;
    sum_b = 0;
    // read the transmission data and set LED values
    for (int idx = 0; idx < num_leds; idx++) {
      byte r, g, b;
      if (!checkIncommingData()) {
        transmissionSuccess = false;
      r = Serial.read();
      g = Serial.read();
      b = Serial.read();
      leds[idx].r = r;
      leds[idx].g = g;
      leds[idx].b = b;
    // shows new values
    if (transmissionSuccess) {
      #if MAX_LEDS > 1
      FastLED.show();
      #endif
} // end of setup
  // Not used. See note in setup() function.
nun meine Frage die mir ständig durch den Kopf geht ^^ das Sketch war nur für ein RGB Strip ausgelegt ,muss ich das Sketch für meine RGBIC Strip anpassen oder passt das so ?
Ambilight funktioniert mit diesem Sketch nur sehe ich keinen Unterschied zu dem RGB Strip das ich vorher nutze ^^
Mit freundlichen Grüßen
Red
Gib uns bitte Links zu den Teilen. Google findet allen unmöglichen Müll zu der Stripe-Bezeichnung.
Gruß Tommy
Sorry hab ich mich vielleicht falsch ausgedrückt ^^ in der Suche bei Amazon eingeben nicht bei Google ^^ aber hier gerne die Links ^^
Strip:
RGBIC Strip
und das Board
ATmega328
Sowas kenne nicht, musst schon den Freundlichen Chinesen fragen was dir das verkauft hat.
Na ja wen man aber RGB IC WS2812B schreibt dann passt das schon ein wenig mehr.
Wie auch? Ist normaler RGB Streifen Du wolltest bestimmt ein RGBW Strip kaufen
Nein Nein ^^Ich wollte einen RGB IC Strip haben , da dieser ja mehr Farben darstellen kann also jede LED kann mehr Farben oder alle können ihre eigene Farbe darstellen lol schlecht erklärt aber ich denke du weißt was ich meine hust ^^
Du meinst RGB IC WS2812B an dieser Stelle setzen ? ```
**#define LED_TYPE WS2812B **
Habe RGB IC vor das WS2812B gesetzt aber leider bekomme ich nun eine Fehlermeldung
mit diesen Fehlermeldungen :
`FastLED.addLeds<LED_TYPE, LED_PINS, COLOR_ORDER>(leds, ledCount);`
error: no matching function for call to 'CFastLED::addLeds(CRGB [216], int&)'
Ich wüsste jetzt nicht, wieso er das können sollte. Jede Farbe wird mit einem Wert von 0-255 gefüttert. Also ein ganz normaler 24Bit-Farbwert pro Pixel. Der die LEDs ansteuernde Chip ist ein Ws2812B. Egal, ob da IC, Eco oder Ratzulpatuff hintendran steht :wink:
Für wirklich mehr Farben sollte es dann tatsächlich ein RGBW-Strip sein.
