sketch help
i am new to microcontrolers i have a uno and getting started with sketches book i have a sketch that want compile no matter what i do can anyone help i dont know where the smiley face came or how te sketch got mixed up the error i get on line 27 expected primary expression before int
// Lesson 4.5 Adding output, Relays etc. with hysterisis
#include "DHT.h"
#include <LiquidCrystal.h>
#include <Wire.h>
#define DHTPIN 2     // what pin we're connected to
#define tempcontpin8   //temp output to control
#define humcontpin4    //humidity output to control
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
int maxF=0, minF=212;
int maxH=0, minH=100;
LiquidCrystal lcd(8,9,4,5,6,7,
dht(DHTPIN2, DHTTYPE(22,
//here's where the temp and hum setpoints are changed
int (tempset=85, tempreset=83;
int humset=55, humreset=53;
int tmem=0, hmem=0;
  Serial.println("DHTxx test!");
  dht.begin();
  lcd.begin(20, 4); // Set the display to 20 columns and 4 rows
  lcd.clear();
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  float tF= (t* 1.8) +32; //convert to Farenheit
  // check if returns are valid, if they are NaN (not a number) then something went wrong!
  if (isnan(t) || isnan(h)) {
    Serial.println("Failed to read from DHT");
  else {
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperature: ");
    Serial.print(t);
    Serial.println(" *C");
    Serial.print(tF);
    Serial.println(" *F");
    lcd.setCursor(0,0);
    lcd.print("Temp ");
    lcd.print(tF);
    lcd.write(B11011111); // print degree symbol
    lcd.print("F ");
    lcd.setCursor(20,0);
    lcd.print("Hum ");
    lcd.print(h);
    if (tF>maxF) {
      maxF=tF;
    }  //check for max temp
    if (tF<minF) {
      minF=tF;
    }  //check for min temp
    lcd.setCursor(0,1);
    lcd.print("H=");
    lcd.print(maxF);
    lcd.print("F L=");
    lcd.print(minF);
    lcd.print("F ");
    if (h>maxH)  {
      maxH=h;
    }  //check for max hum
    if (h<minH)  {
      minH=h;
    }  //check for min hum
    lcd.setCursor(20,1);
    lcd.print("max=");
    lcd.print(maxH);
    lcd.print(" min=");
    lcd.print(minH);
    //Here's the section for control with hysterisis
    if (tempreset<=tF && tF<=tempset && tmem==1) {
      digitalWrite (8, HIGH);
     if (tF>=tempset) {
      tmem==1,
     if (tF<tempreset)  {
      tmem==0,
      digitalWrite (8, LOW);
    if (humreset<=h && h<=humset && hmem==1) {
      digitalWrite (4, HIGH);
     if (h>humset) {
      hmem==1,
    if (h<humreset) {
      hmem==0,
      digitalWrite (4, LOW);
I've never been able to get code with smiley faces to compile, either. I think you just need to throw your Arduino away.
Either that or post the code properly. Modify your post. Delete the code. Select the # icon from the bottom row. Paste your code between the ] and the [ (where the cursor will be positioned).
Paste the error messages, too.
Then, save the changes.
 if (h>humset) {
      hmem==1,
    if (h<humreset) {
      hmem==0,
Sometimes (more often than not, actually), semicolons work better than commas.
Also look up the difference between == (equality test) and = (assignment).
