Sketch in IDE verify or upload only once then error
Hello,
I have Win10x64, Aduino IDE verify or upload clean sketch (or any other) to Nano only once, next time I get error:
Error compiling for board Arduino Nano.
If I restart IDE, or change Board to any other and press Verify it's compile normal, but second press Verify again give error.
I'm already try to clean reinstall on other disk, use "portable" version - nothing works.
Thanks in advance for help!
Here is the same problem on Stack. The only way for now is to downgrade a version, in my case 1.8.8 solve the problem.
@rabbit009
More often than not such issues tend to be a local issue.
Maybe the wrong board was selected ?
Maybe the wrong flavour of board was selected ?
Maybe the wrong COM port was selected for an upload ?
This could also be the fact that a computer may not be the users own personal computer ?
Or some additional security software such as antivirus ?
Or in extreme cases a virus itself ?
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
ballscrewbob:
@rabbit009
  1. If wrong board is seleted it don't work at all, even first time.
    2-3. The same as first answer.
    Everything was selected right, I get an error even when board don't connected at all when just click Verify on start screen clean sketch.
  2. It's my computer with admin rights, if you mean it.
  3. Nothing additional, even shutdowned all stock antivirus as possible.
  4. I have clean install in month earlier and know how to use a computer and and don't try get a will of a nigerian prince:)
Anyway, problem was solved in easy way.
rabbit009:
Great; do you mind sharing the root cause and the solution?
rabbit009:
what is your solution i have been fighting this problem :o :grin:
rabbit009:
oh nvm that is the solution,, THANK YOU FOR REAL,, that has been a headache
