Sketch is not working with Nano perfectly like Mega2560
it was the first portion of the code, since it was too long, I have to post it in 2 parts..
below is the rest of the code..
 static int rangeVal;
    // Start a range measurement in single shot mode//
   WriteByte(0x018, 0x01);
// poll for new sample ready ready //
 VL6180X_Poll_Range();
   // delay(50);
Serial.print("Stage:");
Serial.println(next_stage);
switch (next_stage)
    case getreading: // stage 1
         rangeVal = readByte(0x062);  //read the sensor value
         Serial.print(rangeVal);      //print the sensor value
         Serial.println("mm");        //print the mm
       if (rangeVal<=150 && rangeVal>50 ) {  //turn on the pump below 15 cm
          counter++;                   //starts counter at 0 and increase it by 1 step   // prevents falls triggering when something swipes below the sensor above some speed
          Serial.println(counter);
          Serial.print("millis() :");
          Serial.println(millis());
          //digitalWrite(42,HIGH);
          //digitalWrite(42,LOW);
          if(counter == 12)                // hand should remain in sensor area for counterx27 milliseconds
          counter = 0;             //make the counter 0
          digitalWrite(D4,HIGH);  //pump LED high
          digitalWrite(D8,HIGH);  //pump high
          Serial.println("pump is high");
          next_stage= valveon;}
    else {
          counter = 0;           //makes the counter 0
          digitalWrite(D4,LOW);  //pump LED low
          digitalWrite(D8,LOW);  //pump low
          digitalWrite(D6,LOW);  //turn off valve LED
          digitalWrite(D10,LOW);  //turn off valve
          next_stage=getreading;}
    break;
case wait:    //stage 2
  counter2 = 0;          //makes the counter2 0
  if (rangeVal <100){            // to spray even if pump is turned off
      next_stage= get_time;
  if (rangeVal > 180)
    next_stage = getreading;        //if no hand, jumps to stage 1
break;
 case valveon:  //stage 3
        rangeVal = readByte(0x062);      //read the value from sensor
        Serial.println("mm");            //print mm
      if (rangeVal<=100 ){ //&& rangeVal>=50 ) {
      next_stage=get_time;            // to turn the valve on
      else if (rangeVal<150 && rangeVal>100)
        next_stage=valveon;              //will stay in same stage
        counter2++;                                      //turn off the pump after sometime if hand remain between 10 and 15cm
        Serial.println(counter2);
        Serial.print("millis()stage3 :");
        if (counter2 >= 15)           // to turn the pump off after counter2x42 milliseconds
          next_stage = wait;           //jumps to stage 2
        next_stage=getreading;        //jumps to stage 1
        break;
case get_time: //stage 4
            if (analogRead(A0)>700 ){                              //valve open for 250 milliseconds
              targettime=millis()+250;
            else if (500<analogRead(A0) && analogRead(A0)<600 ){    //valve open for 500 milliseconds
              targettime=millis()+500;
            else  if (300<analogRead(A0) && analogRead(A0)<400 ){    //valve open for 750 milliseconds
              targettime=millis()+750;
            else if (200<analogRead(A0) && analogRead(A0)<300){      //valve open for 1000 milliseconds
              targettime=millis()+1000;
             else if (100<analogRead(A0) && analogRead(A0)<200 ){     //valve open for 1250 milliseconds
              targettime=millis()+1250;
              else if (analogRead(A0)<100 ){                         //valve open for 1500 milliseconds
              targettime=millis()+1500;
        next_stage=check_time;
             digitalWrite(D6,HIGH);                                 //valve high LED
             digitalWrite(D10,HIGH);                                 //valve high
        break;
 case check_time: //stage 5
         Serial.print (rangeVal);
       Serial.println (" mmstage5"  );                           // reads the sensor value
       if (millis() > targettime || rangeVal>=150 || rangeVal<50)  // set the condition when valve goes off
       {//Serial.print("millis 1:");                            //checks when valves goes off
        //Serial.println(millis());
        digitalWrite(D6,LOW);                             //valve LED off
        digitalWrite(D10,LOW);                             //Valve off
              next_stage=pumpoff;
       break;
case pumpoff:                 //stage 6
rangeVal = readByte(0x062);   // measureas the sensor value
Serial.println (" mmstage6"  );
if (counter4 == 0)             // checks the counter4 if it is 0   counter 4: evertime ,turn off the pump after valve closes
   waittime = millis() + 100;    // set wait time for 100 milliseconds
 counter4 = 1;                  // makes the counter4 equal to 1
        if ( millis() >= waittime)        // sets the condition when pump goes off after valve goes off
        {//Serial.print("millis 2:");       // prints millis
       digitalWrite(D8,LOW);                  //pump off
       digitalWrite(D4,LOW);                //pump led off
      if (rangeVal > 180)                       // if no hand
        counter4 = 0;                            // counter4 equal to 0
       break;
default:
// clear interrupts //
   WriteByte(0x015,0x07);
  delay (100); // wait 0.1 seconds}
           }}} // end of loop
vl6180x application note.pdf (690 KB)
