Sketch isn't looping/Locking up?
The servo portion of this sketch worked fine before all the ESP8266 added in. There was a thermistor getting a temp reading, that is now replaced by a 0 or 1 value being read from ThingSpeak.
If I comment out line 59 and 63 the sketch loops fine. It pulls the data from thingspeak just fine.
Obviously moving that servo is the whole point of the sketch. I can't figure out why it isn't looping.
The point of the MoveTo is to detach the servo, and only attach it if the mbrVint value changes state.
This part worked fine on another sketch that had alot of other code in it doing a thermistor temp reading and averaging.
When the sketch starts, the servo does attach, moves to the MBRclosePos (mbrVint is 0), stays attached for 1000ms, then detaches. However the sketch doesn't loop after that as it should. Serial output stops.
ESP8266 Code below that is freezing. I've stripped out as much as possible of unnecessary stuff and still able to replicate the problem.
// D0=16, D1=5, D2=4, D3=0, D4=2, D5=14, D6=12, D7=13, D8=15
#include <ThingSpeak.h>
#include <ESP8266WiFi.h>
#include <Servo.h>
const char* ssid          = "NOTYOURS";
const char* password      = "12345678";
WiFiClient  client;
// Master Bedroom Stuff
Servo servo1;
const int servo1Pin           = 13;   //Master Bedroom - D1
const int MBRopenPos          = 0;
const int MBRclosePos         = 180;
unsigned long myChannelNumber = 123456;
const char * myReadAPIKey     = "APIKEYHERE";
String mbrV                   = "";
void MoveTo(int position) {
  static int lastPosition = -1;
  if (position != lastPosition) {  // Position changing
    servo1.attach(servo1Pin, 785, 2180);  // Set limits of pulse width in microseconds
    servo1.write(position);
    delay(1000);  // Give the servo time to move to the new position
    servo1.detach();  // Disconnect servo to reduce currrent load and servo life
    lastPosition = position;
  delay(10);
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  int wifi_ctr = 0;
    Serial.print(".");
  Serial.println("WiFi connected");
  Serial.print("IP Address: ");
  ThingSpeak.begin(client);
mbrV = ThingSpeak.readFloatField(myChannelNumber, 4, myReadAPIKey);
int mbrVint = mbrV.toInt();
  Serial.print("Master Bedroom Valve Status: ");
   if (mbrVint >= 1) {
    Serial.println("Open");
    MoveTo(MBRopenPos);
  if (mbrVint <= 0) {
    Serial.println("Closed");
    MoveTo(MBRclosePos);
Here is the serial output:
Connecting to NOTYOURS
...WiFi connected
IP Address: 192.168.0.30
Master Bedroom Valve Status: Closed
I now have it looping, until the mbrVint changes values. It completes the servo move, then freezes. I'm SOOOO close I can smell it!!!
#include <Servo.h>
WiFiClient  client;
const unsigned long SampleInterval = 500;
Servo servo1;
const char * myReadAPIKey     = "*************";
String mbrV                   = "";
  delay(10);
  int wifi_ctr = 0;
    Serial.print(".");
  static unsigned long lastSampleTime = 0;
  unsigned long currentTime = millis();
  if (currentTime - lastSampleTime >= SampleInterval) {
    lastSampleTime = currentTime;
    if (mbrVint >= 1) {
      MoveTo(MBRopenPos);
    if (mbrVint <= 0) {
I doubt that it really is freezing. More likely, it is doing something, but you can't see it. If you added two three lines at the very top of the Loop to turn a LED on, wait half a second, then turn the LED off, I bet it would continue to blink. More likely is that the thingspeak is returning for example the same relative value again and again. That gets interpreted to move to a specific Position. The move doesn't take place because that Position is already the current Position and everything starts all over again.
