Sketch LCD not operating after power-cycle, heartbeat ok. LCD/RTC issue? UNO
I'm working with a very simple RTC Time/Date sketch that works perfect after loaded, and when powered continuously after the load. I can plug in a power supply before unplugging the USB cable, and everything continues to operate. But if the power is removed, it restarts to a blank back lit LCD display, with the heartbeat LED blinking.
I'm feeling there is an LCD issue.
The odd part is, I must load a different RTC date/time sketch, then after that, reload of the below date-time sketch for it to operate. Reloading the same sketch will not restore operation.
See below non-restarting sketch.
Any advice greatly appreciated.
#include <Wire.h>
//#include "RTClib.h"
#include <TimeLib.h>
#include <DS1307RTC.h>
LiquidCrystal_I2C lcd(0x27,16,2);
#define LEDBLINK_PIN    13
#define LEDBLINK_MS     1000
lcd.begin();
 lcd.backlight();
  lcd.setCursor(0, 0);
 pinMode(LEDBLINK_PIN, OUTPUT);
  tmElements_t tm;
  ledBlink();
  if (RTC.read(tm)) {
    lcd.setCursor(0,0); //Start at character 0 on line 0
    lcd.print("TIME: ");
    lcd.setCursor(6,0);  //was commented
    print2digits(tm.Hour);
    lcd.print(':');
    print2digits(tm.Minute);
    lcd.print(':');
    print2digits(tm.Second);
    lcd.setCursor(0,1); //Start at character 0 on line 1
    lcd.print("DATE: ");
    lcd.print(tm.Month);
    lcd.print('/');
    lcd.print(tm.Day);
    lcd.print('/');
    lcd.print(tmYearToCalendar(tm.Year));
  delay(990);
void print2digits(int number) {
  if (number >= 0 && number < 10) {
    lcd.print('0');
  lcd.print(number);
void ledBlink()  // Heartbeat LED
  static unsigned int  ledStatus = LOW;  // Last set LED mode.
  static unsigned long ledBlinkTime = 0; // LED blink time.
  if ( (long)(millis()-ledBlinkTime) >= 0 )
    // Toggle LED.
    ledStatus = (ledStatus==HIGH ? LOW : HIGH);
    // Set LED pin status.
    digitalWrite(LEDBLINK_PIN, ledStatus);
    // Reset "next time to toggle" time.
    ledBlinkTime = millis()+LEDBLINK_MS;
Why do you include "RTClib.h", the RTC object is defined in DS1307RTC.h.
Provide links to the hardware you're using and a wiring diagram.
I left it unnecessarily from previous testing.
Its gone.
