For some reason my sketch just waits at a screen on the LCD with nothing but blocks on rows 1 and 3 for like 3 seconds (no doubt just normal boot time) but then stays there won't go any further until I turn my rotary knob left, then it proceeds with the code normally.
I'm sure the reason is obvious and staring me right in the face but this is someone else's code I modded and I'm a noob in the worst way, so I thought I'd throw the problem out here.
EDIT: It just dawned on me that there's a load cell circuit that's not connected at the moment, so perhaps it's waiting for that or something. Of course this only occurred to me AFTER I posted this thread and now I can't delete it and wait until I test this idea first.
Anyway here's part of the code in question:
#include <Wire.h>
#include "HX711.h"
LiquidCrystal_I2C lcd(0x27,20,4);
HX711 scale(5, 6);
#define clk 2
#define dt 3
#define sw 4
#define in1 7
#define in2 8
#define in3 9
#define in4 10
#define in5 11
#define in6 12
#define in7 13
#define in8 14
volatile boolean TurnDetected;
volatile boolean up;
bool doonce = 0;
char screen = 0;
boolean changestate = 0;
long weight;
int pump1ml = 20;
int pump2ml = 20;
int pump3ml = 20;
int pump4ml = 20;
void isr0 () {
TurnDetected = true;
up = (digitalRead(clk) == digitalRead(dt));
lcd.init();
lcd.backlight();
pinMode(sw, INPUT_PULLUP);
pinMode(clk, INPUT);
pinMode(dt, INPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(in5, OUTPUT);
pinMode(in6, OUTPUT);
pinMode(in7, OUTPUT);
pinMode(in8, OUTPUT);
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
digitalWrite(in5, LOW);
digitalWrite(in6, LOW);
digitalWrite(in7, LOW);
digitalWrite(in8, LOW);
attachInterrupt (0, isr0, RISING);
if (TurnDetected) {
delay(200);
doonce = 0;
if (changestate == 0) {
if (up) {
screen++;
if (screen > 4) {
screen = 4;
else {
screen = screen - 1;
if (screen < 0) {
screen = 0;
else {
if (up) {
switch (screen) {
case 0: pump1ml = pump1ml + 10;
case 1: pump2ml = pump2ml + 10;
case 2: pump3ml = pump3ml + 10;
case 3: pump4ml = pump4ml + 10;
else {
switch (screen) {
case 0: pump1ml = pump1ml - 10;
case 1: pump2ml = pump2ml - 10;
case 2: pump3ml = pump3ml - 10;
case 3: pump4ml = pump4ml - 10;
TurnDetected = false;
if (digitalRead(sw) == LOW) {
delay(200);
changestate = !changestate;
doonce = 0;
