Sketch not incrementing
Good day,
Hope someone can point out what I’m doing wrong. I am trying to build a led strip light that will cycle through the assigned colours, however in “void loop” my variable “colour” is not incrementing. This is part of a larger sketch, but need to get this part going.
#include <FastLED.h>
#define LED_PIN 7
#define NUM_LEDS 28
int colour = 0;
CRGB leds[NUM_LEDS];
FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
switch(colour){
case 0: // White
LEDstring(255, 255, 255); break;
case 1: // Red
LEDstring(255, 0, 0); break;
case 2: // Orange
LEDstring(255, 100, 0); break;
case 3: // Yellow
LEDstring(255, 175, 0); break;
case 4: // Green
LEDstring(0, 255, 0); break;
case 5: // Blue
LEDstring(0, 0, 255); break;
case 6: //violet
LEDstring(255, 0, 175); break;
colour++;
if (colour > 6){
//colour = 0; //shut off for troubleshooting
void LEDstring(int r, int g, int b){
Serial.print(“colour: “);
Serial.print(colour);
Serial.print(”\t(”);
Serial.print(r);
Serial.print(", “);
Serial.print(g);
Serial.print(”, “);
Serial.print(b);
Serial.println(”)");
for (int x = 0; x <= NUM_LEDS; x++){
leds = CRGB(r, g, b);
FastLED.show();
The serial monitor shows the variable “colour” never increments.
colour: 0 (255, 255, 255)
Try
++colour
G
Thanks for answering, but I have tried ++colour; with no difference. I've even tried colour = colour + 1;
There’s your problem:
oqibidipo:
Thank you, that worked. But why is “<=” affecting my count on another variable?
colour is immediately after leds[] in memory. Setting leds[NUM_LEDS] to white overwrites colour to 0xFFFF == -1 which is then incremented back to 0.
oqibidipo: colour is immediately after leds[] in memory. Setting leds[NUM_LEDS] to white overwrites colour to 0xFFFF == -1 which is then incremented back to 0.
I carefully chose a variable that was not a reserved word in c. It's not making sense to me. As far as I can see, the only way colour is changed is when it's updated itself. Why would leds[] affect the variable "colour", note it's not "color". I need this to make logical sense.
Valid index values for the leds array are 0 to NUM_LEDS-1. leds[NUM_LEDS] is outside the array and this is where colours is located in memory.
Thank you for that explanation. I understand now. 8)
