Hi all,
I use Controllino Maxi with Ariadne Bootloader (ethernet bootloader · Issue #13 · CONTROLLINO-PLC/CONTROLLINO_Library · GitHub). Everything works fine exept when I power the device off and on again, the device is stuck in the bootloader and I need to press reset button for sketch to run. This is a problem since the device is meant to be at a remote location. The original bootloader did not have this issue.
Thanks for any advices.
