Sketch not loading to board
Actually, I am encountering some problems with uploading my code to the board. The code doesn't actually have any problems as when I verify it, it works; however, when I actually try to upload the code, I get the following error:
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
An error occurred while uploading the sketch
Could you please tell me what this error means and how to fix it?
Thanks!
What operating system are you using?
Have you selected the correct board and port from the Tools menu?
the code doesn't actually have any problems as when I verify it, it works
Note that verify means that it compiles, not necessarily that it works :slight_smile: .
