I'm working on a project using the CQ Robot DMX shield and the Conceptinetics DMX library. I'm having a problem with one of the examples from the library.
If I upload it to the Arduino it runs fine and it turns an LED on/off based on the DMX value as expected.
But if I unplug the Arduino from power and plug it back in, the sketch doesn't seem to work anymore. The LED light doesn't respond to the DMX value.
Any idea what could cause this?
Here's the example sketch.
DMX_Slave.ino - Example code for using the Conceptinetics DMX library
Copyright (c) 2013 W.A. van der Meeren <danny@illogic.nl>. All right reserved.
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 3 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include <Conceptinetics.h>
// CTC-DRA-13-1 ISOLATED DMX-RDM SHIELD JUMPER INSTRUCTIONS
// If you are using the above mentioned shield you should
// place the RXEN jumper towards G (Ground), This will turn
// the shield into read mode without using up an IO pin
// The !EN Jumper should be either placed in the G (GROUND)
// position to enable the shield circuitry
// OR
// if one of the pins is selected the selected pin should be
// set to OUTPUT mode and set to LOGIC LOW in order for the
// shield to work
// The slave device will use a block of 10 channels counting from
// its start address.
// If the start address is for example 56, then the channels kept
// by the dmx_slave object is channel 56-66
#define DMX_SLAVE_CHANNELS 10
// Pin number to change read or write mode on the shield
// Uncomment the following line if you choose to control
// read and write via a pin
// On the CTC-DRA-13-1 shield this will always be pin 2,
// if you are using other shields you should look it up
// yourself
///// #define RXEN_PIN 2
// Configure a DMX slave controller
DMX_Slave dmx_slave ( DMX_SLAVE_CHANNELS );
// If you are using an IO pin to control the shields RXEN
// the use the following line instead
///// DMX_Slave dmx_slave ( DMX_SLAVE_CHANNELS , RXEN_PIN );
const int ledPin = 13;
// the setup routine runs once when you press reset:
// Enable DMX slave interface and start recording
// DMX data
dmx_slave.enable ();
// Set start address to 1, this is also the default setting
// You can change this address at any time during the program
dmx_slave.setStartAddress (1);
// Set led pin as output pin
pinMode ( ledPin, OUTPUT );
// the loop routine runs over and over again forever:
// EXAMPLE DESCRIPTION
// If the first channel comes above 50% the led will switch on
// and below 50% the led will be turned off
// NOTE:
// getChannelValue is relative to the configured startaddress
if ( dmx_slave.getChannelValue (1) > 127 )
digitalWrite ( ledPin, HIGH );
digitalWrite ( ledPin, LOW );
