Hey. I've just gotten into programming with Arduino and have borrowed a Mega 2560 clone board for testing my sketches. But when I try to upload a test sketch to turn on an LED, the sketch doesn't seem to get updated on the board itself, even though the rx light blinks during upload and no errors show up on the output. When I go into the serial monitor, I see the output for an example sketch from some IR library that was apparently uploaded to the board before I got my hands on it. Pressing the reset button or trying to upload a blank sketch doesn't work. I'm using the latest version of the Arduino 2.x IDE. How should I fix this ? I have confirmed that the led works, I'm wiring through I breadboard. This is my first post, so please excuse mistakes!
My output in the IDE: Use code tags to format code for the forum
Sketch uses 1334 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
My program:
pinMode(2, OUTPUT);
digitalWrite(2, HIGH);
It turns out, I had actually changed the port but hadn't updated in the IDE for this particular upload. But I fixed that and the original problem still persists, without any apparent errors in the output...
Here's the new output:
FQBN: arduino:avr:mega
Using board 'mega' from platform in folder: /Users/Siddhu/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
Using core 'arduino' from platform in folder: /Users/Siddhu/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
Detecting libraries used...
/Users/Siddhu/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -I/Users/Siddhu/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Siddhu/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/mega /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/sketch/BareMinimum.ino.cpp -o /dev/null
Generating function prototypes...
/Users/Siddhu/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -I/Users/Siddhu/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Siddhu/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/mega /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/sketch/BareMinimum.ino.cpp -o /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/4118549820/sketch_merged.cpp
/Users/Siddhu/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/4118549820/sketch_merged.cpp
Compiling sketch...
/Users/Siddhu/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -I/Users/Siddhu/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/Siddhu/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/mega /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/sketch/BareMinimum.ino.cpp -o /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/sketch/BareMinimum.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/cores/arduino_avr_mega_cpu_atmega2560_1f37b8b4dd29b296b762e1c4d7701583/core.a
Linking everything together...
/Users/Siddhu/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega2560 -o /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/BareMinimum.ino.elf /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/sketch/BareMinimum.ino.cpp.o /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/../../cores/arduino_avr_mega_cpu_atmega2560_1f37b8b4dd29b296b762e1c4d7701583/core.a -L/private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD -lm
/Users/Siddhu/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/BareMinimum.ino.elf /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/BareMinimum.ino.eep
/Users/Siddhu/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -R .eeprom /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/BareMinimum.ino.elf /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/BareMinimum.ino.hex
/Users/Siddhu/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-size -A /private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/BareMinimum.ino.elf
"/Users/Siddhu/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude" "-C/Users/Siddhu/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega2560 -cwiring "-P/dev/cu.usbserial-110" -b115200 -D "-Uflash:w:/private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/BareMinimum.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/Siddhu/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/Siddhu/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbserial-110
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: reading input file "/private/var/folders/mx/_kbrjzmj3d9f5136wqz9qgn00000gp/T/arduino/sketches/4228508A3FAB46CE152AAC84276B8BCD/BareMinimum.ino.hex"
avrdude: writing flash (1334 bytes):
Writing | ################################################## | 100% 0.20s
avrdude: 1334 bytes of flash written
avrdude done. Thank you.
I used the "Bare Minimum" sketch but added my own code in to test:
pinMode(2, OUTPUT);
How is the led connected to pin 2. Perhaps it is connected backwards, or perhaps it is burned out, or not wired correctly. If you connect the led to the 5V pin, does it light up?
You would do better to test the Mega itself with the "Blink" sketch using the onboard led.
If the Mega is indeed working without problems, then you can figure out why your led is not working with pin2.
I'm starting to think this is an error with the board's USB to Serial Convertor not updating the EEPROM memory even though it shows it is in the output. But this is just a guess...
(Excuse any wrong terminology as I'm new to Arduino)
I tried the blink program, it doesn't light up any extra led on the board
Since this is a borrowed and unknown Mega, the onboard led is perhaps not working. Can you try some of the other basic example sketches.
What is the usb interface chip, and do you have the driver for that installed on the computer? I'm not familiar with Linux and how what errors related to the USB port are detected and reported.
If none of the basic example sketches work, and the driver is correct and if the 2580 chip is not being written by the usb converter then that could be a hardware defect on the board. Perhaps a broken trace, or a lifted pin, or a defective processor or interface chip.
If you had a scope or logic analyzer you might be able to figure out what is wrong, but how much time and energy to do you have to spend on this board?
What do you mean by a scope or logic analyzser ? Is it some other board that I would have to get or a piece of software that I could install on my computer ? I could try to get that as I really don't want to condemn the board without trying all reasonable avenues that wouldn't cost too much. Thanks.
I'm not familiar with a Mac. I know there have been some issues reported with version of the OS and some boards.
Have you tried with 1.8.19?
If you have successfully used the computer and version of the OS before, you have probably done all the basic "reasonable" things.
I can't be of much more help. Perhaps if you retitled posting to be more Mac specific you might be able to get some others involved. If you make the posting both Mac and V2.x specific, @pert who monitor V2.x issues might get involved.
Hi @sid_g1. Since there is some doubt about the reliability of the approach of using the LED as an indicator of whether the new sketch program is running on the board, I'll suggest an alternative experiment:
Try uploading this sketch to your Arduino board:
Copy and paste this code as a new sketch in Arduino IDE:
