Sketch not uploading for one laptop but uploads on my other laptop
I am completely new to electronics and I just started using the Arduino. I am currently following the Arduino Projects Book and I'm on page 33 (SPACESHIP INTERFACE). I wired and coded as shown but I keep getting this error:
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Arduino Uno"
Sketch uses 1160 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\david\AppData\Local\Temp\arduino_build_425444/sketch_aug30a.ino.hex:i
An error occurred while uploading the sketch
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
option enabled in File -> Preferences.
This is on my surface book but on my MacBook, I'm able to run the code successfully and upload it to my Arduino. The same coding was used on my Macbook and the response I got back is this:
/private/var/folders/8w/hbbq42l90td32ywv76pqrvr00000gn/T/AppTranslocation/44EFD233-48DD-4FD2-B667-8A02F1BB9F51/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/private/var/folders/8w/hbbq42l90td32ywv76pqrvr00000gn/T/AppTranslocation/44EFD233-48DD-4FD2-B667-8A02F1BB9F51/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem14201 -b115200 -D -Uflash:w:/var/folders/8w/hbbq42l90td32ywv76pqrvr00000gn/T/arduino_build_929521/SPACESHIP_INTERFACE.ino.hex:i
System wide configuration file is "/private/var/folders/8w/hbbq42l90td32ywv76pqrvr00000gn/T/AppTranslocation/44EFD233-48DD-4FD2-B667-8A02F1BB9F51/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/davidg/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem14201
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/var/folders/8w/hbbq42l90td32ywv76pqrvr00000gn/T/arduino_build_929521/SPACESHIP_INTERFACE.ino.hex"
avrdude: writing flash (1160 bytes):
Writing | ################################################## | 100% 0.20s
avrdude: 1160 bytes of flash written
avrdude: verifying flash memory against /var/folders/8w/hbbq42l90td32ywv76pqrvr00000gn/T/arduino_build_929521/SPACESHIP_INTERFACE.ino.hex:
avrdude: load data flash data from input file /var/folders/8w/hbbq42l90td32ywv76pqrvr00000gn/T/arduino_build_929521/SPACESHIP_INTERFACE.ino.hex:
avrdude: input file /var/folders/8w/hbbq42l90td32ywv76pqrvr00000gn/T/arduino_build_929521/SPACESHIP_INTERFACE.ino.hex contains 1160 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.16s
avrdude: verifying ...
avrdude: 1160 bytes of flash verified
avrdude done. Thank you.
Not sure what is going on and why it's only uploading and working on my MacBook. If someone can help and clear this for me, that'll be greatful.
