Hello,
It is my first post, so I'll try to do as best as I can.
I have a new Arduino UNO ATMEGA328P-U which was working fine. At a certain point it stopped working the sketch it had loaded and uploading new ones.
When trying to upload a sketch it takes a while until it shows in command window the following error:
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x31
avrdude done. Thank you.
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
Librería inválida encontrada en C:\Users\Pablo\Documents\Arduino\libraries\libraries: C:\Users\Pablo\Documents\Arduino\libraries\libraries
Orange led (L) on pin 13 does not blink, neither RX or TX and ON led stays on during the process of uploading.
I am writing this post as any of the solutions I found on the internet were suitable for my case. The following points have been checked or performed:
• Port is correctly selected and detected by PC
• Board is selected correctly
• USB cable works with other boards
• I have tried in several computers
• Reinstall the Arduino IDE
• Check Arduino drivers to be OK
I have tried to upload "BareMinimum" sketch while pressing the hardware reset button with no success.
I have also tried to burn the bootloader with another working Arduino UNO ATMEGA328P-PU as ISP with no success. The command window shows the following error:
Arduino:1.8.5 (Windows 10), Tarjeta:"Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
Using Port : COM3
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Error quemando bootloader
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
I tried changing the signature number in the file "avrdude.conf" as they both Arduinos do not have exactly the same microcontroller, with the same error above. I changed "0x1e 0x95 0x0F" to "0x1e 0x95 0x14" as suggested in other posts.
I have tried to swap the microcontroller between the two Arduinos used (the one working served as programmer in the burn bootloader process and the target, not working one) resulting in neither of them working and getting the initial error in this post when trying to upload a new sketch
Did I broke the Arduino? Is it a problem with the bootloader or could be something else? Is there something else I can try?
I hope I was clear and gave enough information. Any help is welcome.
Thanks in advance!
