sketch only executes when button is held, not pushed.
hey everyone, I'm trying to execute this command for acceleration of a motor when a button is pushed, but it only seems to work if i hold down the button, rather than just an inturrupt. Any thoughts on this.l
#include <Wire.h>
#include <AccelStepper.h>
#include <Adafruit_MotorShield.h>
int buttonApin = 2;
Adafruit_MotorShield AFMStop(0x60); // Default address, no jumpers
Adafruit_StepperMotor *myStepper2 = AFMStop.getStepper(200, 2);
// wrappers
void forwardstep2() {
  myStepper2->onestep(FORWARD, DOUBLE);
void backwardstep2() {
  myStepper2->onestep(BACKWARD, DOUBLE);
// Accel wrapper
AccelStepper stepper2(forwardstep2, backwardstep2);
  AFMStop.begin(); // Start the bottom shield
  pinMode(buttonApin, INPUT_PULLUP);
  stepper2.setMaxSpeed(500.0);
  stepper2.setAcceleration(50);
  stepper2.moveTo(500);
if (digitalRead(buttonApin) == LOW)
  stepper2.run();
It's only running when you hold the button because that's what you're asking it to do:
If you want to do something on the falling edge of an input, use an interrupt. Something like:
  attachInterrupt(digitalPinToInterrupt(buttonApin), RunStepper, FALLING);
  //interrupt handler takes care of falling edges being detected
void RunStepper() {
  stepper2.run();
Do you want the stepper to run when the button becomes pressed rather than when it is pressed ? If so then look at the StateChangeDetction example in the IDE
When should the stepper stop ?
BlackFin, i tried running your code and I wind up getting nothing happening. no errors, just no actions. I THOUGHT it would behave the same as when i run this code. The difference being the " "stepper2.moveTo(500);"
If I remove the "if" statement, the stepper accelerates up and then down for 500 steps with the origional code posted.
UKHeliBob - ill check out the state change thanks. im hoping to just set a number of steps, say 500 then have it stop, which i thought would happen with the setup logic.
#include <Wire.h>
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
//Naming the buttons
int buttonApin = 2;
int buttonBpin = 3;
int ledPin = 6;
  myMotor->setSpeed(50);
  AFMS.begin(1600);
  pinMode(ledPin, OUTPUT);
  pinMode(buttonBpin, INPUT_PULLUP);
   int sensorVal = digitalRead(2);
    myMotor->release();
    digitalWrite(ledPin, HIGH);
   myMotor->step(100, FORWARD, DOUBLE);
   digitalWrite(ledPin, LOW);
Which platform are you using? Check this page:
to determine if your board supports interrupts on the digital input(s) you're using.
Im running an UNO with an adafruit motorshiled V2
