I am trying to log sensor readings from the BH1750 and DHT22 sensors using the Adafruit Data Logger Shield. The sketch I has properly writes the readings to the serial monitor, but only writes/prints one set of readings to the SD card. Is their an order to the delay and close commands I am messing up?
/* This is the initial project code for the IRES Arduino project using both the DHT22 sensor and BH1750 sensor*/
//Libraries
#include "RTClib.h";
#include "SD.h";
#include <DHT.h>
#include <Wire.h>
#include <SPI.h>
//Constants
#define LOG_INTERVAL 3000 // mills between entries
#define ECHO_TO_SERIAL 1 // echo data to serial por
#define DHTPIN 2 // what pin we're connected to
#define DHTTYPE DHT22 // DHT22/AM2302
DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
int chk;
float hum; //Stores humidity value
float temp; //Stores temperature value
int BH1750_address = 0x23; // i2c Addresse
byte buff[2];
//Object and Error
RTC_PCF8523 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
const int chipSelect = 10; // for the data logging shield, we use digital pin 10 for the SD cs line
File logfile; // the logging file
void error(char *str)
Serial.print("error: ");
Serial.println(str);
while(1);
void setup(void)
Serial.println("IRES");
// initialize the SD card
Serial.print("Initializing SD card...");
pinMode(10, OUTPUT); // make sure that the default chip select pin is set to output, even if you don't use it:
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.print("Card fails, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
Serial.print("Logging to: ");
Serial.println(filename);
//For DHT22 and BH1750
dht.begin();
Wire.begin();
BH1750_Init(BH1750_address);
//For RTC
if (!rtc.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
logfile.println("runtime,time,hum,temp,lux");
#if ECHO_TO_SERIAL
Serial.println("runtime,time,hum,temp,lux");
#endif
//Additional Coding for BH1750
void BH1750_Init(int address){
Wire.beginTransmission(address);
Wire.write(0x10); // 1 [lux] resolution
Wire.endTransmission();
byte BH1750_Read(int address){
byte i=0;
Wire.requestFrom(address, 2);
while(Wire.available()){
buff[i] = Wire.read();
i++;
return i;
DateTime now;
// delay for the amount of time we want between readings
delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
// runtime, log milliseconds since starting
uint32_t runtime = millis();
logfile.print(runtime);
logfile.print(", ");
#if ECHO_TO_SERIAL
Serial.print(runtime);
Serial.print(", ");
#endif
// now, log actual time using RTC
now = rtc.now();
logfile.print(now.year(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(daysOfTheWeek[now.dayOfTheWeek()]);
logfile.print(") ");
logfile.print(now.hour()-6, DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
logfile.print(":");
logfile.print(now.second(), DEC);
#if ECHO_TO_SERIAL
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(" (");
Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
Serial.print(") ");
Serial.print(now.hour() -6, DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
//For DHT22
//Read data and store it to variables hum and temp
hum = dht.readHumidity();
temp= dht.readTemperature();
logfile.print(hum);
logfile.println(temp);
//Print temp and humidity values to serial monitor
#if ECHO_TO_SERIAL
Serial.print("Humidity: ");
Serial.print(hum);
Serial.print(" %, Temp: ");
Serial.print(temp);
Serial.println(" Celsius");
//For BH1750
delay(2000);
float valf=0;
if(BH1750_Read(BH1750_address)==2){
valf=((buff[0]<<8)|buff[1])/1.2;
logfile.print((int)valf,DEC);
#if ECHO_TO_SERIAL
Serial.print("Light: ");
if(valf<0)Serial.print("> 65535");
else Serial.print((int)valf,DEC);
Serial.print(" lux");
#endif
//Time between readings
delay(3000); //wait x min before next read/write
// close the file:
logfile.close();
