Hello! I just got my Arduino Uno a few weeks ago and have been learning the ropes since I got it. I have no prior programming knowledge and the most small electronics work I've done is wiring up a few LEDs, but I'm learning and have had a lot of fun with it.
The point of this project is to implement a couple fancy features in a car that I'm restoring. The first thing I want to achieve is simply fading on the courtesy and dome lights (which are LEDs) when one of the doors is open, and off when they're both closed. The second thing I want to implement is a simple push button that will be located somewhere on the drivers side. When it's pressed, the next time the driver door is open, the window will automatically roll down; when the door is closed, the window will roll back up. The button will have to be pressed each time before it will do this.
I have written a completely functional sketch and prototyped it on a breadboard using a red/green LED to simulate the window. Being new to programing, I'm sure I've used the long winded, inefficient way to achieve much of what I did, and the eventual goal is, if possible, to use an ATtiny chip to control these functions in the car. So I would like the sketch to be as concise and efficient as possible, and I was hoping I could get some suggestions on what I can do to improve it and get some input on how an ATtiny (probably an 84 or 85) will handle this sketch.
/* This sketch has two purposes and is designed for use in a car. The first
purpose of this sketch is to fade a set of LEDs on when the car door is opened,
then fade them back off when the car door is closed. The second purpose of
this sketch is to make a push button that when pressed, the door window will
roll down when the door is opened, then roll back up when the door is clossed.*/
// Define the pins the pushbutton and door switches are on
const int buttonPin[] = {2, 4, 6};
// Define the pins that will ultimately control the window rolling up or down
const int windowPin[] = {7, 8};
// Define the pin the LEDs to fade are on
const int ledPin = 3;
// Define the amount of time the fade delay will be
const int fadeDelay = 15;
// Define the brightness increase interval
const int fadeAmount = 3;
// Define the delay for button debounce
const int debounceDelay = 15;
// Define the amount of time the windows will spend rolling up and down.
//rollUpDelay will be longer to ensure window rolls all the way up.
const int rollUpDelay = 3000;
const int rollDownDelay = 2000;
//Variables that will change
// Variable to track the current state of the push button, in an array the size
//of buttonPin.
boolean currentButtonVal[3];
// Initialize variables to define and store the debounced switch values. doorSwitch
//is in an array the size of buttonPin
boolean doorSwitch[3];
boolean windowButton;
// Define the inital brightness of the LED. Starts off, or 0
int brightness = 0;
// Define the inital "previous time" variable for comparison with millis().
//Will start at 0 and be redifned every time fadeDelay has passed.
unsigned long previousTime = 0;
// Define the inital comparison time for the debounce function. Has the same
//purpose as in "previousTime."
unsigned long lastDebounceTime = 0;
// Initialize a variable that is set to millis() every time a button state is
//toggled. In an array the size of buttonPin[], and is unique to each button.
unsigned long toggleTime[3];
// Define the inital state for a button toggle. This value will be reversed
//when a button is pressed. In an array the size of buttonPin[], and is unique
//to each button.
boolean buttonToggle[3] = {false};
// Initialize a variable to track if the rollWindow function should be active
boolean rollWindowToggle;
// Initialize a variable to detect if the rollWindow button should finish
boolean continueFunction;
void setup () {
pinMode (buttonPin[0], INPUT);
pinMode (buttonPin[1], INPUT);
pinMode (buttonPin[2], INPUT);
pinMode (windowPin[0], OUTPUT);
pinMode (windowPin[1], OUTPUT);
pinMode (ledPin, OUTPUT);
void loop () {
// Create a variable to store the millis() value this time through the loop
unsigned long currentTime = millis();
// Define variables to debounce and keep track of the different switches
doorSwitch[0] = debounce(0);
doorSwitch[1] = debounce(1);
windowButton = debounce(2);
// If either car door is open, then fade the LEDs. If both car doors are
//closed, then fade the LEDs off.
if (doorSwitch[0] == HIGH || doorSwitch[1] == HIGH) {
if (currentTime - previousTime > fadeDelay) {
previousTime = currentTime;
brightness = brightness + fadeAmount;
// Limit the fade amount from going above 255
brightness = min(brightness, 255);
analogWrite (ledPin, brightness);
else {
brightness = brightness - fadeAmount;
// Limit the fade amount from going bellow 0
brightness = max(brightness, 0);
// If windowButton has been toggled to true (on) and the door switch is HIGH,
//then make rollWindowToggle true. This allows the rollWindow function to
//begin. If buttonToggle is not true (on), then make rollWindowToggle false.
if (buttonToggle[2] == true) { //Start function when buttonToggle is true
if (doorSwitch[0] == HIGH) { //If the door is open
rollWindowToggle = true; //Let the rollWindow function execute
else rollWindowToggle = false;
// Test to see if rollWindowToggle was toggled on while the door was open,
//if it was, then reset toggleTime so the window will still roll the correct
//amount of time. continueFunction must not equal true so toggleTime does not
//continuously reset if rollWindowToggle gets toggled while the function is
//in progress.
if (rollWindowToggle == false && doorSwitch[0] == HIGH && continueFunction != true) {
toggleTime[0] = millis();
// Iniate rollWindow function if either requirment is meant. continueFunction
//tracks if the function should continue, even if rollWindowToggle is
//toggled to false.
if (rollWindowToggle == true || continueFunction == true) {
// Iniate rollWindow function, doorSwitch and toggleTime indicate which
//switch will activate the function. currentTime passes the variable assigned
//to millis().
rollWindow(0, currentTime);
void rollWindow (int thisSwitch, unsigned long currentTime) {
// Switch case to control what happens when the door is open or closed
switch (doorSwitch[thisSwitch]) {
// If the door is open:
case HIGH:
// Define the state of continueFunction to indicate that the function is
//in progress and should continue until it is complete
continueFunction = true;
// If the rollDownDelay time has passed, stop rolling the window. If not,
//roll the window down. Make windowPin[1] LOW to ensure the window will
//not try to roll down and up at the same time.
if (currentTime - toggleTime[thisSwitch] > rollDownDelay) { //If roll up time has passed:
digitalWrite (windowPin[0], LOW); //Stop rolling the window down
else {
digitalWrite (windowPin[1], LOW); //Make sure the window is not rolling up
digitalWrite (windowPin[0], HIGH); //Make the window roll down
// If the door is closed:
case LOW:
// If the rollUpDelay time has passed, stop rolling the window, reset
//buttonToggle[2] to false, and make continueFunction false to indicate
//the function is complete. If rollUpDelay time has not passed, then
//roll the window up and make windowPin[0] LOW to ensure the window will
//not try to roll up and down at the same time.
if (currentTime - toggleTime[thisSwitch] > rollUpDelay) {
buttonToggle[2] = false;
continueFunction = false;
else {
digitalWrite (windowPin[1], HIGH);
// Create a debounce function to debounce the switches, start the toggleTime
//timer, and toggle the buttonToggle variable. Return the value current.
boolean debounce(int thisButton) {
// Take a reading of the switch pin and store it in a local variable.
boolean current = digitalRead(buttonPin[thisButton]);
// If the reading does not equal the current recorded state of the button,
//wait the debounceDelay, then take another reading of the currenet value and
//begin the toggle timer. If the state of the switch is high, then toggle
//buttonToggle.
if (currentButtonVal[thisButton] != current) {
if (millis() - lastDebounceTime > debounceDelay) {
toggleTime[thisButton] = millis();
if (current == HIGH) {
buttonToggle[thisButton] = !buttonToggle[thisButton];
// Record the curent button value and return current
currentButtonVal[thisButton] = current;
return current;
Thanks a bunch!
Acliad
