Sketch resetting unexpectedly
I have this Sketch to try the ESP8266 board with an Arduino UNO. I supplied external power to the UNO to prevent lack of juice. I get the following output on the Monitor serial window (showing reset and garbage characters). Don´t know what is happening here, might it be a problem with the SoftwareSerial library? Otherwise doing what I was expecting!!!! Any advice or insight most appreciated.
AT+RST
Module dosn't respond.
Please reset.
Init - ESP8266 Demo
AT+RST
WiFi - Module is ready
AT+CWMODE=1
AT+CWJAP="{MySSID}","{MySSID password}"
Connected to WiFi...
Temp: 24.89 C Presion: 970.86 Humedad: 84%
--------------------------------1
-KR+‹�- ESP8266 Demo
AT+RST
AT+CWMODE=1
--Init - ESP8266 Demo
AT+RST
Please reset.
// Example adapted from
// http://zeflo.com/2014/esp8266-weather-display/
// in turn reworked from:
// http://www.seeedstudio.com/wiki/WiFi_Serial_Transceiver_Module
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
#include <SoftwareSerial.h>
//#include <JsonParser.h> couldn't find this one!!!! use ArduinoJson instead
#define SSID "{MySSID}"
#define PASS "{MySSID password}"
// obtiene datos del clima
// localidad id: Coatepec=3530531, Xalapa=3526617
#define LOCATIONID "3530531"
//"188.226.224.148" //api.openweathermap.org
#define DST_IP "78.46.48.103"
SoftwareSerial dbgSerial(2,3);
// Función para conectar a WiFi con la tarjeta ESP8266
boolean connectWiFi()
  Serial.println("AT+CWMODE=1");
  String cmd="AT+CWJAP=\"";
  cmd+=SSID;
  cmd+="\",\"";
  cmd+=PASS;
  cmd+="\"";
  dbgSerial.println(cmd);
  delay(2000);
  if(dbgSerial.find("OK")){
    dbgSerial.println("OK, Connected to WiFi.");
    return true;
  }else{
    dbgSerial.println("Can not connect to the WiFi.");
    return false;
  dbgSerial.setTimeout(5000);
  dbgSerial.begin(9600); // for debuging
  Serial.println("Init - ESP8266 Demo");
  // Prueba que el módulo esté funcionando
  Serial.println("AT+RST");
  // reset and test if module is redy
  dbgSerial.println("AT+RST");
  if(dbgSerial.find("ready")) {
    Serial.println("WiFi - Module is ready");
  }else{
    Serial.println("Module dosn't respond.");
    Serial.println("Please reset.");
    while(1);
  // Intenta conectar el módulo al wifi
  boolean connected=false;
  for(int i=0;i<5;i++){
    if(connectWiFi()){
      connected = true;
      Serial.println("Connected to WiFi...");
  if (!connected){
    Serial.println("Coudn't connect to WiFi.");
    while(1);
  delay(5000);
  dbgSerial.println("AT+CIPMUX=0"); // set to single connection mode
  // Conceta con la pagina del servicio del estado del tiempo
  String cmd = "AT+CIPSTART=\"TCP\",\"";
  cmd += DST_IP;
  cmd += "\",80";
  // Envía el comando y espera por una respuesta, si hay algún error reintenta!
  if(dbgSerial.find("Error")) return;
  cmd = "GET /data/2.5/weather?id=";
  cmd += LOCATIONID;
  cmd += " HTTP/1.0\r\nHost: api.openweathermap.org\r\n\r\n";
  // wait for prompt then send data
  dbgSerial.print("AT+CIPSEND=");
  dbgSerial.println(cmd.length());
  if(!dbgSerial.find(">"))
    dbgSerial.println("AT+CIPCLOSE");
    Serial.println("connection timeout");
    return;
  dbgSerial.print(cmd);
  // Recorre el puerto serial hasta encontrar el segmento "main":{
  while (!dbgSerial.find("\"main\":{")){}
  // Lee el bloque hasta encontrar el corchete de cierre: "}"
  unsigned int i = 0; //timeout counter
  int n = 1; // char counter
  char json[100]="{";
  while (i<60000)
    if(dbgSerial.available())
      char c = dbgSerial.read();
      json[n]=c;
      if(c=='}') break;
      n++;
      i=0;
    i++;
  // Step 1: Reserve memory space
  StaticJsonBuffer<200> jsonBuffer;
  // Step 2: Deserialize the JSON string
  JsonObject& root = jsonBuffer.parseObject(json);
  if (!root.success())
    Serial.println("parseObject() failed");
    return;
  // Step 3: Retrieve the values
  double temp = root["temp"];
  double presion = root["pressure"];
  byte humedad = root["humidity"];
  temp -= 273.15; // from kelvin to degree celsius
  // Muestra los resultados de la consulta web
  Serial.print ("Temp: ");
  Serial.print (temp);
  Serial.print (" C ");
  Serial.print ("    Presion: ");
  Serial.print (presion);
  Serial.print ("   Humedad: ");
  Serial.print (humedad);
  Serial.println ("%");
  Serial.println ("--------------------------------1");
  Serial.println ("--------------------------------2");
You have 3 while loops that looks strange : nothing happens onthe while condition.
I have reformatted your code and pointed out the while loops :
SoftwareSerial dbgSerial(2, 3);
  String cmd = "AT+CWJAP=\"";
  cmd += SSID;
  cmd += "\",\"";
  cmd += PASS;
  cmd += "\"";
  delay(2000);
  if (dbgSerial.find("OK"))
    return true;
    return false;
  // reset and test if module is ready
  if (dbgSerial.find("ready"))
    while (1); // < ------------------------- ********************* !!!!!!!!!!!!!!!!!!!! what, empty while loop ?
  boolean connected = false;
  for (int i = 0; i < 5; i++)
    if (connectWiFi())
      connected = true;
  if (!connected)
  delay(5000);
  cmd += DST_IP;
  cmd += "\",80";
  if (dbgSerial.find("Error")) return;
  cmd += LOCATIONID;
  if (!dbgSerial.find(">"))
    return;
  while (!dbgSerial.find("\"main\":{")) {} // < ------------------------- ********************* what, empty while loop ?
  char json[100] = "{";
  while (i < 60000) // < ------------------------- ********************* this is a correct while structure
    if (dbgSerial.available())
      json[n] = c;
      if (c == '}') break;
      n++;
      i = 0;
    i++;
    return;
