Perhaps the compiler can see that the variable led1 is never updated, so it optimises it as a constant requiring only 1 byte. It would do this no matter what type byte/int/long you make it.
Try
volatile int led1 = 4;
and then change the int to byte or long. The volatile keyword tells the compiler not to make assumptions/optimisations about the variable, but the compiler might still not be fooled by that, I don't know.
The optimizer really does it's best for you, but to see effects you will need a more expanded program than what you are doing now. Even if the compiler doesn't see it as a constant, it will know where it is used, and if it is used as an argument for a function that takes a 16 or 8 bit value, the variable will get truncated to that unless it is modified somewhere.
Reducing variable sizes can make a huge difference, for instance if you use millis() but can make do with a 16-bit value, do so !
Avoid floating point variables since using them requires the use of special functions that will need to be compiled.
If you define something like
#define ECHO 14
#define VALUE 23 * ECHO + 12
you will find that when using VALUE somewhere, you can reduce flash by adding braces
#define (VALUE 23 * ECHO + 12)
Forcing the compiler to do the calculation instead of the MCU from within the sketch.
Please post the code you are trying to use (within code tags </> no screenshot !) and the board you are compiling for (and the core you are using)
So i can re-create and show you how it does work.
