Sketch stop looping!!? NRF24L01 transmitter
Hello~ :slight_smile:
I am learning about NRF24L01 and I tried making a simple project that I could communicate two Arduinos, one as a Transmitter and the other as a Receiver, sending and receiving information at the same time.
Its basically two Arduinos(UNO) with a Led and a Pushbutton connected in both. If I press the pushbutton, the Led at the other Arduino will turn ON.
It is working, but the Transmitter suddenly stops looping(I think). The program stops completly about 5 or 10 seconds after a turn on.
Im using a 100miliseconds delay, I realized that the faster the sketch goes the faster it stops looping. If I use 10miliseconds delay it stops in about 2 seconds.
I can see by the Serial monitor that only the transmitter arduino stops looping, while the other arduino(receiver) works fine and keep waiting for a signal from the transmitter(that is frozen).
Before the transmitter stops(5 to 10 seconds after turn on), everything works fine.
--> Here is the TRANSMITTER CODE:
// TRANSMITTER
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define button 3
#define led 2
RF24 radio(7, 8); // CE, CSN
const byte addresses[][6] = {"00001", "00002"};
boolean buttonState = 0;
boolean recbutton = 0;
unsigned long timer = 0;
  pinMode(led, OUTPUT);
  pinMode(button, INPUT_PULLUP);
  radio.begin();
  radio.setPALevel(RF24_PA_MIN);
  radio.setDataRate(RF24_2MBPS);
  radio.setChannel(124);
  radio.openWritingPipe(addresses[1]); // 00002
  radio.openReadingPipe(1, addresses[0]); // 00001
  buttonState = digitalRead(button);
  radio.stopListening();
  if (!radio.write( &buttonState, sizeof(buttonState) )) {
    Serial.println("No acknowledgement of transmission - receiving radio device connected?");
  } else{
    Serial.print("Sent button: ");
    Serial.println(buttonState);
  delay(100);
  radio.startListening();
  timer = millis();
  while(!radio.available()){
    if(millis() - timer >= 200){
      Serial.println("No response received - timeout!");
      return;
  radio.read(&recbutton, sizeof(recbutton));
  if(recbutton == 1){
    digitalWrite(led, LOW);
  } else{
    digitalWrite(led, HIGH);
  Serial.print("Received Button: ");
  Serial.println(recbutton);
  delay(100);
--> Here is the Receiver code:
// RECEIVER
#include <SPI.h>
#include <RF24.h>
#define button 3
#define led 2
  radio.begin();
  radio.openWritingPipe(addresses[0]); // 00002
  radio.openReadingPipe(1, addresses[1]); // 00001
  if(radio.available()){
    while(radio.available()){
    if(recbutton == 1){
    } else{
    delay(100);
    if(radio.write(&buttonState, sizeof(buttonState))){
      Serial.print("Sent button state: ");
    } else{
      Serial.println("Sent failed");
    delay(100);
I tried to check the connections and the sketch, but everything looks fine, I really have no idea what is the problem.
Thank you!
Have a look at this Simple nRF24L01+ Tutorial.
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
...R
Ok, I will learn from there and try again.
Thank you!
