Hi gang!
I see the wifi example sketch already uses 81% of my Leonardo board program storage space.
Is there a way to get if shaved down 10% ish?
The rest of my code would be quite small..
If its not possible, what board would have bigger program storage but still on ATmega32u4 and work with the shield?
Thanks
what example exactly?
wifi101's (the libraries) connectWithWPA
This example connects to an unencrypted WiFi network.
Then it prints the MAC address of the WiFi shield,
the IP address obtained, and other network details.
Circuit:
* WiFi shield attached
created 13 July 2010
by dlf (Metodo2 srl)
modified 31 May 2012
by Tom Igoe
#include <SPI.h>
#include <WiFi101.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the WiFi radio's status
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
// attempt to connect to WiFi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the data:
Serial.print("You're connected to the network");
printCurrentNet();
printWiFiData();
// check the network connection once every 10 seconds:
delay(10000);
printCurrentNet();
void printWiFiData() {
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
Serial.println(ip);
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
printMacAddress(mac);
void printCurrentNet() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the MAC address of the router you're attached to:
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
printMacAddress(bssid);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.println(rssi);
// print the encryption type:
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type:");
Serial.println(encryption, HEX);
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
if (i > 0) {
Serial.print(":");
would it be worth buying a new one and setting up arduino to arduino connecition? so 1 arduino would just read wifi and the other would actually do what i want.
try some real sketch. this prints too much without F() macro and uses functions you normally don't use.
but strange is, it doesn't take so much flash on Uno.
you could use Uno WiFi, Nano 33 iot or MKR 1010. it is much better then to use two Arduinos
I'm not too sure what you mean by real sketch. I removed all prints and serial references in general, but still 106% in my real example. F macro seems good idea, I'm new to Arduino, but will have a look. Also my other option to go into the wifi101 library and try removing stuff I don't need. Whats wierd is that this shield (Adafruit) uses Wifi101 opposed to regular wifi library I'd expected on first round ...
pretty much this is what i want to achieve, to send commands from other computer via tcp:
I'll try manufacturer forum as well then.
Thanks @Juray
getting back to v0.8.0 of the library saved some space... still craving for more
