Hi guys, i need a urgent help about my final project. Two sketches should unify and two seperated gps info should be seen(One from remote and other is own). Firts code shows gps location info received via xbee from another arduino.It works successfully .The second sketch (worked good also) shows own location info acquired via gps module and connected to arduino. I tried some methods like ".listen" for multidevice or multi serial connection but somehow it didnt work.If you could reply and help id be so pleased.From now thanks for your reply and help.Regards,Faruk
SKETCH FOR RECEIVING GPS INFOS FROM ANOTHER ARDUINO VIA XBEE
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
long t1;
String st, lon_val, lat_val;
int val;
//08.08.2014--17:48
static const int RXPin = 9, TXPin = 8;
static const uint32_t GPSBaud = 4800;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(9, 8);
pinMode(13, OUTPUT);
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
//ss.begin(GPSBaud);
t1 = millis();
void parseData()
if(st.indexOf(" ")>=0)
lon_val = st.substring(0,(st.indexOf(" ")));
lat_val = st.substring(st.indexOf(" ")+1);
lon_val = st;
val = 0;
static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
//GPS alam?yoruz
//printFloat(gps.location.lat(), gps.location.isValid(), 11, 6);
//printFloat(gps.location.lng(), gps.location.isValid(), 12, 6);
if (Serial.available())
st = String("");
while(Serial.available())
st = st + char(Serial.read());
delay(1);
parseData();
//Serial.print(st);
//Serial.print("\t");
Serial.print(lon_val);
Serial.print("\t");
Serial.println(lat_val);
t1 = millis();
if(lon_val.indexOf("LED1ON")>=0)
if ((millis() - t1)<(val*1000))
digitalWrite(13,HIGH);
else if((millis() - t1) >(val*1000))
digitalWrite(13,LOW);
digitalWrite(13, LOW);
static void printFloat(float val, bool valid, int len, int prec)
if (!valid)
while (len-- > 1)
Serial.print('*');
Serial.print(' ');
Serial.print(val, prec);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1); // . and -
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(' ');
smartDelay(0);
static void smartDelay(unsigned long ms)
unsigned long start = millis();
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
SKETCH FOR GETTING GPS INFOS.
// Constants
#define txPin 8 //tx pin in GPS connection
#define rxPin 9 //rx pin in GPS connection
// Set up the GPS serial port
SoftwareSerial gps = SoftwareSerial(rxPin, txPin);
// Variables
byte byteGPS = 0;
int i = 0;
int state = 0;
char dataGPG[100]="";
char *pch;
char *GGA[15];
int sat = 0;
//setup for Serial Port
Serial.flush();
//setup for GPS Serial Port
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
gps.begin(4800);
gps.flush();
//setup satellites signal
digitalWrite(13, LOW); // Turn off the led until a satellite signal
gps.flush();
Serial.flush();
Serial.println("Waiting GPS data...");
// Prepare all for reading GPS Serial Port
memset(dataGPG, 0, sizeof(dataGPG)); // Remove previous readings
byteGPS = 0; // Remove data
byteGPS = gps.read(); // Read the byte that is in the GPS serial port
// Find the desired string
while(byteGPS != '
// Save the string in an array
i=1;
dataGPG[0] = '
while(byteGPS != '*' )
dataGPG[i]=byteGPS;
i++;
dataGPG[i]= '\0';
string(); // Call to the function that manipulates our string
This function will allow us to identify the data we need to get the longitude, latitude ...
void string()
i=0;
memset(GGA, 0, sizeof(GGA)); // Remove previous readings
pch = strtok (dataGPG,",");
// Analyze the saved interval in pch to see if it the needed string
if (strcmp(pch,"$GPGGA")==0)
while (pch != NULL)
pch = strtok (NULL, ",");
GGA[i]=pch;
i++;
plot(GGA,"$GPGGA"); // Call to the function that is going to display the data
This function organize the gps data received for printing in the serial monitor.
void plot(char **GGAPrint, char *trama)
state = atoi(GGAPrint[5]);
sat = atoi(GGAPrint[6]);
if(trama=="$GPGGA" && state==1)
digitalWrite(13, HIGH); // Then there are satellites, the LED switch ON
Serial.println("");
Serial.println("----------------------------------------------");
Serial.print("UTC Hour -> ");
Serial.println(GGAPrint[0]);
Serial.print("Latitude -> ");
Serial.print(GGAPrint[1]);
Serial.println(GGAPrint[2]);
Serial.print("Longitude -> ");
Serial.print(GGAPrint[3]);
Serial.println(GGAPrint[4]);
Serial.print("GPS quality: 0=null; 1=GPS fixed -> ");
Serial.println(GGAPrint[5]);
Serial.print("Number of satellites -> ");
Serial.println(sat);
Serial.print("Horizontal Dilution of Precision -> ");
Serial.println(GGAPrint[7]);
Serial.print("Antenna altitude -> ");
Serial.print(GGAPrint[8]);
Serial.println(GGAPrint[9]);
Serial.print("Geoid Separation -> ");
Serial.print(GGAPrint[10]);
Serial.println(GGAPrint[11]);
Serial.println("");
else // If no satellite connection
digitalWrite(13, LOW); // Turn off the LED
Serial.println("");
Serial.println("-----------------------------");
Serial.print("|--- Satellites Used -->");
Serial.print(sat);
Serial.println(" |");
Serial.println("|----Waiting location----|");
Serial.println("");
