I'm out of digital outputs and need to consider using D0 and D1 in my program. If the only serial usage I require is to upload sketches with the Arduino 1.0 app, do I need to put any special code into my sketch to enable sketch loading, or can I just put them into the desired mode and work, as with any other pin?
You can "just use them", but be warned that whatever you connect to them might interfere with the serial signal coming into/out of the chip. You might need to disconnect the pins when you want to upload.
Did you know you can use the analogue inputs as digital outputs?
That's awesome!!!!!
I've got 5 more digital outs!!!!
renniejohnson:
That's awesome!!!!!I've got 5 more digital outs!!!!
six ![]()
