Sketch Warnings
So I'm trying to Verify this Sketch for my Project and this comes up.
C:\Users\Ali\Desktop\Arduino_101_Blynk_BLE\Arduino_101_Blynk_BLE.ino: In function 'void setup()':
C:\Users\Ali\Desktop\Arduino_101_Blynk_BLE\Arduino_101_Blynk_BLE.ino:39:34: warning: 'void BlynkCurieBLE::begin(const char*, BLEPeripheral&)' is deprecated (declared at C:\Users\Ali\Desktop\Arduino_101_Blynk_BLE\arduino-1.6.13\libraries\Blynk\src/BlynkSimpleCurieBLE.h:146) [-Wdeprecated-declarations]
   Blynk.begin(auth, blePeripheral);
Sketch uses 104,232 bytes (66%) of program storage space. Maximum is 155,648 bytes.
I would like to know if this will be a problem, if so how can I fix it?
Please post your code and we can see what the errors are pointing to.
What Arduino are you using?
Thanks.. Tom.. :slight_smile:
Deprecated generally means "will disappear sometime in the future". However, I have seen such things never removed.
In any case, the solution is simple: reverse the parameters in the call to Blynk.begin.
#define BLYNK_PRINT Serial
#include <BlynkSimpleCurieBLE.h>
#include <CurieBLE.h>
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
  char auth[] = "c7459ff0a86745be9d71680223c5440a";
BLEPeripheral  blePeripheral;
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Select which 'port' M1, M2, M3 or M4.
Adafruit_DCMotor *motor1 = AFMS.getMotor(1);
Adafruit_DCMotor *motor2 = AFMS.getMotor(2);
//######### SETUP ######################################
  // The name your bluetooth service will show up as, customize this if you have multiple devices
  blePeripheral.setLocalName("SwagMobile");
  blePeripheral.setDeviceName("SwagMobile");
  blePeripheral.setAppearance(384);
  blePeripheral.begin();
  Serial.println("Waiting for connections...");
  Serial.println("Adafruit Motorshield v2 - DC Motor");
  AFMS.begin();  // create with the default frequency 1.6KHz
  //AFMS.begin(1000);  // OR with a different frequency, say 1KHz
  // Set the speed to start, from 0 (off) to 255 (max speed)
  motor1->setSpeed(255);
  motor2->setSpeed(255);
//########## LOOP ######################################
  Blynk.run();
  blePeripheral.poll();
//######### Subrutines ################################
// This function will set the speed
BLYNK_WRITE(V0)
  int pinValue = param.asInt(); // assigning incoming value from pin V1 to a variable
  // You can also use:
  // String i = param.asStr();
  // double d = param.asDouble();
  Serial.print("V0 Slider value is: ");
  Serial.println(pinValue);
  motor1->setSpeed(pinValue);
  motor2->setSpeed(pinValue);
// Motor 1 Forward
BLYNK_WRITE(V1)
  Serial.print("Motor 1 Forward: ");
  if(pinValue == 1) {
    motor1->run(FORWARD);
  if(pinValue == 0) {
    motor1->run(RELEASE);
// Motor 2 Forward
BLYNK_WRITE(V2)
  Serial.print("Motor 2 Forward: ");
  if(pinValue == 1) {
    motor2->run(FORWARD);
  if(pinValue == 0) {
    motor2->run(RELEASE);
// Motor 1 Backward
BLYNK_WRITE(V3)
  Serial.print("Motor 1 Backward: ");
  if(pinValue == 1) {
    motor1->run(BACKWARD);
  if(pinValue == 0) {
// Motor 2 Backward
BLYNK_WRITE(V4)
  Serial.print("Motor 2 Backward: ");
  if(pinValue == 1) {
    motor2->run(BACKWARD);
  if(pinValue == 0) {
I am using an Arduino 101
@CodingBadly
I have downloaded this Sketch of a website and am applying it on my Project. I have no experience in coding so if you could please show me how to reverse the parameters
ALIMONK:
I have no experience in coding…
At this point, your coding experience is irrelevant. A reasonable understanding of the English language, which you have demonstrated, is all that is necessary to complete the task.
I will help you if you get stuck.
@CodingBadly
Thank you, It is no longer giving Errors.
You are welcome.
