Sketch will not compile - NodeMCU-32s
This relatively simple sketch will not compile.
The error message is - error compiling for board NodeMCU-32s
Before I start looking into potential hardware issues, would SKS please cast an eye over my program ( I am very much a novice) to see if it has any significant errors which might prevent it from compiling.
 //Project to make 8 buttons inputs on GPIO Pins 16,17,18,19,21,22,23,25
 //Each button takes Pin from HIGH to LOW
 //Trigger 8 relays attached to GPIO Pins 2,4,5,13,26,27,32,33.
 // Relays are triggered by LOW signal on Pins 2,4,5,13,26,27,32,33
uint8_t gpios[] = {16,17,18,19,21,22,23,25};  // 8 NO button inputs
  // Number of GPIOs in Button Array
int gpioCount;
uint8_t relays[] = {2,4,5,13,26,27,32,33};  // 8 relay Outputs
int relayCount; //Number of Relays in Relay array
 gpioCount = sizeof(gpios)/sizeof(uint8_t);
 //for each pin in the gpio array
    for(int i=0; i<gpioCount; i++){
    //Set the GPIO mode as input pulled high
    pinMode(gpios[i], INPUT_PULLUP);
   //for each pin in the relay array
    for(int n=0; n<relayCount; n++){
                        //Set the GPIO mode to output
    pinMode(relays[n], OUTPUT);
void loop(){
    uint8_t values[gpioCount];
                  //For each gpio
                  //Reads the value (HIGH or LOW) of the gpio
                          //and stores the value on the array
 values[i] = digitalRead(gpios[i]);
                 //For each relay pin
              //Sets the relay pin outputs to match the gpio of each button pressed
    digitalWrite(relays[n], values[i]);
   Serial.print ("relays and values");
  Serial.println(relays[n], values[i]);
                    //print gpios array values for reference
  Serial.print("gpioCount: ");
  Serial.println(values[i]);
It would save time if you posted the error message too.
Please post the full error message using the "Copy error messages" link in the IDE
It compiles for UNO so there's no basic problem.
Full error message as requested split into too posts because of size
Arduino: 1.8.13 (Windows 7), Board: "NodeMCU-32S, 80MHz, 921600"
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino:10:15: error: redefinition of 'uint8_t gpios []'
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti.ino:10:9: note: 'uint8_t gpios [8]' previously defined here
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino:11:5: error: redefinition of 'int gpioCount'
int gpioCount; // Number of GPIOs in Array 1
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti.ino:12:5: note: 'int gpioCount' previously declared here
int gpioCount;
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino:13:16: error: redefinition of 'uint8_t relays []'
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti.ino:13:9: note: 'uint8_t relays [8]' previously defined here
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino:14:5: error: redefinition of 'int relayCount'
int relayCount; //Number of Relays in relay array
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti.ino:14:5: note: 'int relayCount' previously declared here
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino:16:27: error: array bound is not an integer constant before ']' token
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino: In function 'void setup()':
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino:18:6: error: redefinition of 'void setup()'
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti.ino:17:6: note: 'void setup()' previously defined here
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino: In function 'void loop()':
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino:22:7: error: redefinition of 'void loop()'
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti.ino:36:6: note: 'void loop()' previously defined here
void loop(){
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino:51:5: error: 'values' was not declared in this scope
values = digitalRead(gpios*);*
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino:56:18: error: 'values' was not declared in this scope
_ Serial.println(values*);
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino:56:25: error: 'i' was not declared in this scope
Serial.println(values);
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino:63:29: error: 'values' was not declared in this scope
digitalWrite(relays[n], values);
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_16-46-55-834.ino:63:36: error: 'i' was not declared in this scope
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-19-46-350.ino: At global scope:
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-19-46-350.ino:10:15: error: redefinition of 'uint8_t gpios []'
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-19-46-350.ino:11:5: error: redefinition of 'int gpioCount'
int gpioCount; // Number of GPIOs in Button Array
int gpioCount;
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-19-46-350.ino:13:16: error: redefinition of 'uint8_t relays []'
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-19-46-350.ino:14:5: error: redefinition of 'int relayCount'
^*_
Have you got multiple tabs?
Error message part 2
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-19-46-350.ino: In function 'void setup()':
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-19-46-350.ino:17:6: error: redefinition of 'void setup()'
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-19-46-350.ino: In function 'void loop()':
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-19-46-350.ino:37:7: error: redefinition of 'void loop()'
void loop(){
void loop(){
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-19-46-350.ino:47:5: error: 'values' was not declared in this scope
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-19-46-350.ino:50:29: error: 'values' was not declared in this scope
_ digitalWrite(relays[n], values*);
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-19-46-350.ino:50:36: error: 'i' was not declared in this scope
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-21-55-810.ino: At global scope:
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-21-55-810.ino:10:15: error: redefinition of 'uint8_t gpios []'
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-21-55-810.ino:11:5: error: redefinition of 'int gpioCount'
int gpioCount;
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-21-55-810.ino:13:16: error: redefinition of 'uint8_t relays []'
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-21-55-810.ino:14:5: error: redefinition of 'int relayCount'
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-21-55-810.ino: In function 'void setup()':
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-21-55-810.ino:17:6: error: redefinition of 'void setup()'
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-21-55-810.ino: In function 'void loop()':
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-21-55-810.ino:37:7: error: redefinition of 'void loop()'
void loop(){
void loop(){
^_
C:\Users\Graham\Documents\Arduino\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti\8_channel_relay_control_with_ESP3214-09-2020_GB_TEST_8_connecti-2020-09-14_17-21-55-810.ino:47:5: error: 'values' was not declared in this scope
values _= digitalRead(gpios);
exit status 1
Error compiling for board NodeMCU-32S._
TheMemberFormerlyKnownAsAWOL:
No just the one instance with one sketch open.
ive shut down and reopened the IDE but same problem.
Yes, but have you got multiple tabs in that one instance ?
Not sure what you have done but, you have multiple .ino files in the same directory.
They get combined when doing an IDE build.
These .ino files
appear to all be in this directory:
I don't use the built in editor, but maybe this is some sort of auto save issue?
I would run meld to compare the files, and pick the one with your latest updates and remove the other ones.
--- bill
Thanks bill,
that seemed to do the trick. The sketch now compiles but does produce the output that I want,
Im going back to the drawing board with the code.
