I am fairly new to Ardunio and although doing a thorough search I have a problem I cannot solve.
Code below does not loop and and the last sub loop does not seem to work. Appreciate any help or guidance.
Regards
Ken
Light LEDs on pins 2 to 7 sequentially, each after short delay and leaving all on.
Then turn all Leds off.
Follow by a reverse sequence (eg. Led on pin 7 down to led on pin 2)
Turn all Leds off.
Then loop to start.
int timerS = 30 ;
int timerL = 300 ;
// use as loop to initialize each pin as an output:
for (int thisPin = 2; thisPin < 8; thisPin++) {
pinMode(thisPin, OUTPUT);
// Light up pin 2 to pin 7 with short delay:
for (int thisPin = 2; thisPin <= 8; thisPin++) {
// turn the pin on:
digitalWrite(thisPin, HIGH);
// delay lighting the next LED:
delay(timerS);
//When all LEDS are HIGH, switch to LOW after long delay:
delay(timerL);
digitalWrite (thisPin, LOW);
// After long delay, switch LEDS on one at a time in reverse order:
delay(timerL);
for (int thisPin = 7; thisPin <= 8; thisPin–) {
// turn the pin on:
digitalWrite (thisPin, HIGH);
delay(timerS);
//Turn all LEDs LOW). NOTE: This sub loop below does not do what is intended and all Leds remain HIGH:
// turn the pin off:
digitalWrite(thisPin, LOW);
// Return to restart Loop ():
delay(timerL);
for (int thisPin = 7; thisPin <= 8; thisPin--) {
// turn the pin on:
delay(timerS);
This is not doing what you think it is doing (and some of your other “for” loops also have incorrect “conditions”).
Turn all Leds off.
Then loop to start.
int timerS = 30 ;
int timerL = 300 ;
for (int thisPin = 2; thisPin < 8; ++thisPin) {
int thisPin; //since u are using this variable repeatedly maybe better to declare it at beginnig of loop
for (thisPin = 2; thisPin < 8; ++thisPin) { //no need to used <=
// turn the pin on:
delay(timerS);
delay(timerL);
for (thisPin = 2; thisPin < 8; thisPin++) {
delay(timerL);
for (thisPin = 7; thisPin >1; --thisPin) { // since decrementing should be >= not <=
// turn the pin on:
delay(timerS);
