This sketch will not run due to some problem, please have a look as I need help with this
to create a “fox hunt” beacon for our local Scouts field day.
NT1Ks Fox Box Keyer - 12/2012
This program will key the radio and send an ID in CW at 700Hz
followed up by a 5 second tone to allow others to find the
transmitter.
int const CWLED = 13; // LED to show CW Connect to PIN 13
int const TXLED = 12; // LED to show TX is active to PIN 12
int const CW = 11; // Hook up Microphone to PIN 11
int const TX = 9; // Hook TX up to PIN 9
int const SW = 7; // Momentary Pushbutton to PIN 7
int TONEHZ = 700; // Tone of the CW Signal
int DITLENGTH = 120; // CW Speed, Change for faster/slower CW
int BEEPLENGTH = 5000; // Length of soild tone in ms
int MSGSPACE = 60000; // Space Between Transmissions
int val= 0;
int old_val =0;
int state = 0;
char message[] = "DE NT1K FOXBOX"; //Message Beint Sent
// Following Makes the DAH tone
void dah() {
digitalWrite(CWLED, HIGH); // Turns LED on
tone(CW, TONEHZ); // Sending out tone at 700hz
delay(3*DITLENGTH);
digitalWrite(CWLED, LOW); // Turns off LED
noTone(CW); // Turns off Tone
delay(DITLENGTH);
// Following Makes the DIT tone
void dit() {
tone(CW, TONEHZ);
delay(DITLENGTH);
noTone(CW);
delay(DITLENGTH);
// Following is the Space Between Letters
void letterBreak() {
delay(2*DITLENGTH);
// Following is the Space Between Words
void wordBreak() {
delay(4*DITLENGTH);
// Following replaces each char with its morse code equiv
void send(char letter) {
switch (letter) {
case 'A':
case 'a': dit(); dah(); break;
case 'B':
case 'b': dah(); dit(); dit(); dit(); break;
case 'C':
case 'c': dah(); dit(); dah(); dit(); break;
case 'D':
case 'd': dah(); dit(); dit(); break;
case 'E':
case 'e': dit(); break;
case 'F':
case 'f': dit(); dit(); dah(); dit(); break;
case 'G':
case 'g': dah(); dah(); dit(); break;
case 'H':
case 'h': dit(); dit(); dit(); dit(); break;
case 'I':
case 'i': dit(); dit(); break;
case 'J':
case 'j': dit(); dah(); dah(); dah(); break;
case 'K':
case 'k': dah(); dit(); dah(); break;
case 'L':
case 'l': dit(); dah(); dit(); dit(); break;
case 'M':
case 'm': dah(); dah(); break;
case 'N':
case 'n': dah(); dit(); break;
case 'O':
case 'o': dah(); dah(); dah(); break;
case 'P':
case 'p': dit(); dah(); dah(); dit(); break;
case 'Q':
case 'q': dah(); dah(); dit(); dah(); break;
case 'R':
case 'r': dit(); dah(); dit(); break;
case 'S':
case 's': dit(); dit(); dit(); break;
case 'T':
case 't': dah(); break;
case 'U':
case 'u': dit(); dit(); dah(); break;
case 'V':
case 'v': dit(); dit(); dit(); dah(); break;
case 'W':
case 'w': dit(); dah(); dah(); break;
case 'X':
case 'x': dah(); dit(); dit(); dah(); break;
case 'Y':
case 'y': dah(); dit(); dah(); dah(); break;
case 'Z':
case 'z': dah(); dah(); dit(); dit(); break;
case '0': dah(); dah(); dah(); dah(); dah(); break;
case '1': dit(); dah(); dah(); dah(); dah(); break;
case '2': dit(); dit(); dah(); dah(); dah(); break;
case '3': dit(); dit(); dit(); dah(); dah(); break;
case '4': dit(); dit(); dit(); dit(); dah(); break;
case '5': dit(); dit(); dit(); dit(); dit(); break;
case '6': dah(); dit(); dit(); dit(); dit(); break;
case '7': dah(); dah(); dit(); dit(); dit(); break;
case '8': dah(); dah(); dah(); dit(); dit(); break;
case '9': dah(); dah(); dah(); dah(); dit(); break;
case '.': dit(); dah(); dit(); dah(); dit(); dah(); break;
case ',': dah(); dah(); dit(); dit(); dah(); dah(); break;
case '?': dit(); dit(); dah(); dah(); dit(); dit(); break;
case '-': dah(); dit(); dit(); dit(); dit(); dah(); break;
case '/': dah(); dit(); dit(); dah(); dit(); break;
case '\'': dah(); dah(); dah(); dit(); dit(); dit(); break;
case ' ': wordBreak(); break;
letterBreak();
// Following is the setup for the loop
pinMode (CWLED, OUTPUT); // Defines that the LED is an OUTPUT
pinMode (SW, INPUT); // Defines that the Switch is an INPUT
pinMode (TXLED, OUTPUT); // Defines that the TX (RED) LED is an Output
pinMode (TX, OUTPUT); // Defines TX (PTT)as an Output
pinMode (CW, OUTPUT); // Defines CW (Audio) as an Output
// Following is the acutal program using the above information
void loop(){
val = digitalRead(SW); // Looking for information from the switch
if ((val == HIGH) && (old_val == LOW)) {
state = 1 - state;
delay (1000);
old_val = val;
// When the button is pushed, it will perform the following
if (state == 1) {
digitalWrite(TX, HIGH); // Turns on transmitter PTT
digitalWrite(TXLED, HIGH); // Turns on the TX LED
for (byte j=0; j<sizeof(message); j++) {
send(message[j]);
} // Sends Message
delay(4*DITLENGTH); // Wait
tone(CW, TONEHZ); // Sends out solid tone
delay(BEEPLENGTH); // Wait
noTone(CW); // Shuts off tone
digitalWrite(TX, LOW); // Turns off TX
digitalWrite(TXLED, LOW); // Turns off TX LED
delay(MSGSPACE); // Wait time until repeat
Moderator edit: Bloody CODE TAGS, dammit.
