The progress bar starts then hangs on compile or upload ive tryed this on 2 laptops now both have the same result, ive waited 1 hour and its not getting any further along.
the skech is
#include <SimpleTimer.h>
#include <TFT.h> // Arduino TFT library
#include <SPI.h>
// pin definition for the Uno
#define cs 10
#define dc 9
#define rst 8
// create an instance of the library
TFT TFTscreen = TFT(cs, dc, rst);
// Declare ins for H Bridge
const int motor1Pin = 5; // H-bridge leg 1 (pin 2, 1A)
const int motor2Pin = 6; // H-bridge leg 2 (pin 7, 2A)
const int enablePin = 7; // H-bridge enable pin
byte sensorInterrupt = 0; // 0 = pin 2; 1 = pin 3
byte sensorPin = 2;
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per
// litre/minute of flow.
float calibrationFactor = 4.5;
volatile byte pulseCount;
float flowRate;
float lastFlowRate;
float currentFlowRate;
unsigned int flowMilliLitres;
unsigned long oldTime;
int pumpBlocked;
int rppin = 3; // the pin that the RimsPump is attached to
int PumpRunning ;
int pumpRequired= 14;
// set pump required to input
pinMode (pumpRequired, INPUT);
// set all the other pins you're using as outputs:
pinMode(motor1Pin, OUTPUT);
pinMode(motor2Pin, OUTPUT);
pinMode(enablePin, OUTPUT);
// set enablePin LOW so that motor is off:
digitalWrite(enablePin, LOW);
timer.setInterval (500 , enablePin, HIGH);// Turn ball valve every 1/2 second
timer.setinterval (250, enablePin, LOW) ; // Turn ball valve off every 1/4 second
TFTscreen.begin();
TFTscreen.background(0, 0, 0);
TFTscreen.stroke(255, 255, 255);
TFTscreen.setTextSize(2);
// declare pin 9 to be an output:
pinMode(rppin, OUTPUT);
// Initialize a serial connection for reporting values to the host
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pulseCount = 0;
flowRate = 0.0;
flowMilliLitres = 0;
oldTime = 0;
currentFlowRate = flowRate;
pumpBlocked = 0;
// The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
// Configured to trigger on a FALLING state change (transition from HIGH
// state to LOW state)
attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
void pumpTimeOut(){ // set the time out for blocked pumps
* Main program loop
Serial.println("flow Rate");
Serial.println(flowRate);
Serial.println("Current Flowrate);
Serial.println(currentFlowRate);
Serial.println("Last Flowrate");
Serial.println(lastFlowRate);
if pumprequired (HIGH)
//Pulse pin to slowly run up pump
if (flowRate > 3){ // Ltr's / Min
digitalWrite(motor1Pin, LOW); // set leg 1 of the H-bridge low
digitalWrite(motor2Pin, HIGH); // set leg 2 of the H-bridge high
//Pulse pin to slow pump speed
else if (flowRate < 3){
digitalWrite(motor1Pin, HIGH); // set leg 1 of the H-bridge high
digitalWrite(motor2Pin, LOW); // set leg 2 of the H-bridge low
if (currentFlowRate <= lastFlowRate - 2 )
PumpRunning = 0 , // Stop pump
pumpBlocked +1 ,// Add 1 to pump blocked
// Close ball valve
timerId = timer.setTimeout(10000, pumpTimeout) ;
PumpRunning = 1;
// set text colour to suit pump speed
if (flowRate < 1 ){ TFTscreen.stroke (255, 153, 51);} // Light orange text
else if (flowRate >= 1 && flowRate < 2){ TFTscreen.stroke (255, 128, 0); } // Orange text
else if (flowRate >= 2 && flowRate < 2.5 ){ TFTscreen.stroke (178, 255, 102);} // Light green text
else if (flowRate > 2.5 && flowRate == 3 ){ TFTscreen.stroke (0, 255, 0); } // Green text
else if (flowRate > 3 ){ TFTscreen.stroke (255, 0, 0); } // Red text
if ((millis() - oldTime) > 1000) // Only process counters once per second
// Disable the interrupt while calculating flow rate and sending the value to
// the host
detachInterrupt(sensorInterrupt);
// Because this loop may not complete in exactly 1 second intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output. We also apply the calibrationFactor to scale the output
// based on the number of pulses per second per units of measure (litres/minute in
// this case) coming from the sensor.
flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
// Note the time this processing pass was executed. Note that because we've
// disabled interrupts the millis() function won't actually be incrementing right
// at this point, but it will still return the value it was set to just before
// interrupts went away.
oldTime = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to millilitres.
flowMilliLitres = (flowRate / 60) * 1000;
unsigned int frac;
frac = (flowRate - int(flowRate)) * 10;
TFTscreen.text("FLOW RATE:", 0, 0);
if (int(flowRate) < 10)
TFTscreen.text("", 0, 30),
TFTscreen.print((int)flowRate); // Print the integer part of the variable
TFTscreen.text(".", 0, 30); // Print the decimal point
TFTscreen.print(frac, DEC) ; // Print the fractional part of the variable
TFTscreen.text(" L/Min", 55, 30);
TFTscreen.text("PUMP BLOCKED", 0,70);
TFTscreen.text("",0,90);
TFTscreen.print(pumpblocked);
TFTscreen.text("TIMES",30,90);
if (pumpblocked == 0) {TFTscreen.background(0,255,0) ; } // Green text
else if (pumpblocked >=1 && pumpblocked <=2){ TFTscreen.background(255, 128, 0); } // Orange text
else if (pumpblocked >=3 ){ TFTscreen.background(255,0,0); } // Red text
// Reset the pulse counter so we can start incrementing again
pulseCount = 0;
// Enable the interrupt again now that we've finished sending output
* Invoked by interrupt0 once per rotation of the hall-effect sensor. Interrupt
* handlers should be kept as small as possible so they return quickly.
void pulseCounter()
// Increment the pulse counter
pulseCount++;
im uploading this to an uno.
There may be problems with the sketch (ie the code is wrong or brackets are in the wrong place) but this shouldnt stop it compileing.
Any help greatly appreciated
Pesh
