Sketch won't load after I replug the USB cable.
I’ve spent close to 3 hours troubleshooting this, and I’m getting really stress out :sleeping:
So this is the code in my arduino,
#include <RF24Network.h>
#include <RF24.h>
#include <SPI.h>
RF24 radio(9, 8);
RF24Network network(radio);
//Addresses for the different nodes
const uint16_t master = 00;
const uint16_t slave1 = 01;
const uint16_t slave2 = 02;
//  VARIABLES FOR COMMUNICATION
char tosend_off = '0';
char tosend_on = '1';
char blank = 'r';
// VARIABLES FOR CODE STRUCTURE
int lamp_state = 0;
  pinMode(5, INPUT);
  radio.begin();
  network.begin(90, slave1);
  network.update();
  if(digitalRead(5) == HIGH)
    if(lamp_state == 0)
      RF24NetworkHeader master(master);
      network.write(master, &tosend_on, sizeof(tosend_on));
      lamp_state = 1;
    if(lamp_state == 1)
      network.write(master, &tosend_off, sizeof(tosend_off));
      lamp_state = 0;
Notice the nested If statements I’ve got there. Also, notice the main function i’m doing which is:
For some reason, with the nested If, after I unplug and replug the USB cable, the whole thing doesn’t work… But without the nested If, it will still work after i unplug and replug the USB cable.
So this the code that works:
  network.update();
I’ve no clue… Seriously. Can someone help me? Is there any mistake in my code?
Also, I’m using the Arduino UNO R3, NRF24L01+ Module and the RF24 & RF24Network Libraries
You have some radio connected here , is it using the same pins as the USB ? ( Rx/Thx)
hammy: You have some radio connected here , is it using the same pins as the USB ? ( Rx/Thx)
Nope. The pins that are used are, Digital(9,8,11,12,13)
I also have a button on Digital 5.
That's it
What do you mean by "load" in "Sketch won't load after I replug the USB cable."
Run or upload?
Do you power from USB or differently?
Anyway, you will have to close serial monitor after disconnecting; that might be your problem.
