I’m having issues with a sketch not doing what I want it to. Since I knew this might happen, I included a bunch of Serial.print lines to see if I could figure out where it was going wrong, and so as to focus my efforts.
I have replicated my entire sketch below (it’s not very long) and there are a couple of points at which it should Serial.print but nothing appears in the Serial monitor during sketch run.
Obviously my sketch isn’t working, so if anyone has any pointers as to what’s going wrong too that would be very much appreciated. In terms of what the sketch is trying to achieve:
- Receive an input from somebody typing an instruction into their web browser. Eg, instruction “A110” would be sent by typing 192.168.0.155/?A110 into the web browser.
- Compile this into a string “A110”
- Send this (using the VirtualWire library) through RF to a receiver unit which will take the appropriate action.
#include <Ethernet.h>
#include <SPI.h>
#include <VirtualWire.h>
boolean reading = false;
//CONFIGURE
byte ip[] = { 192, 168, 0, 155 }; //ip address to assign the arduino
byte gateway[] = { 192, 168, 0, 1 }; //ip address of the gatewa or router
//Rarly need to change this
byte subnet[] = { 255, 255, 255, 0 };
// if need to change the MAC address (Very Rare)
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetServer server = EthernetServer(80); //port 80
void setup(){
//Pin 13 has LED connected to it, which we will light up during RF transmission
pinMode(13, OUTPUT);
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
vw_set_ptt_inverted(true); //
vw_set_tx_pin(2);
vw_setup(4000);// speed of data transfer Kbps
void loop(){
// listen for incoming clients, and process qequest.
checkForClient();
void checkForClient(){
if (client) {
// an http request ends with a blank line
boolean currentLineIsBlank = true;
boolean sentHeader = false;
while (client.connected()) {
if (client.available()) {
if(!sentHeader){
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
sentHeader = true;
char buf[VW_MAX_MESSAGE_LEN]; //allocate space for the string
char c =-1; // Where to store the character read
byte index = 0; // Index into array; where to store the character
if(reading && c == ' ') reading = false;
if(c == '?') reading = true; //found the ?, begin reading the info
if(reading){
Serial.print(c);
if(index < VW_MAX_MESSAGE_LEN - 1) // Where receipt is one less than the size of the array
c = client.read(); // Read a character
buf[index] = c; // Store it
index++; // Increment where to write next
else{
buf[index] = '\0'; // Null terminate the string
Serial.print(buf); // Print the final string to the serial monitor
index = 0; // set index back to zero ready for the next input string.
vw_send((uint8_t *)buf, strlen(buf));
vw_wait_tx(); // Wait until the whole message is gone
if (c == '\n' && currentLineIsBlank) break;
if (c == '\n') {
}else if (c != '\r') {
currentLineIsBlank = false;
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection:
