Sketch works for a while then stops working using CC3000 and weather sensors
I built a small weather station that sends the current temperature, humidity and uv to data.sparkfun.com. I have it set to do it every 10000 milliseconds as you can only send new data 100 times in a 15 minute period. Anyways, my code works, it sends the info and I can view it but after about 2 hours or so it just stops working. And I have no idea why. I can solve the problem by resetting the Arduino which to me points to some sort of memory leak. Here is the code, I have a CC3000, DHT22 temperature sensor and the Sparkfun UV sensor all working together. The Code gathers the reading and then the CC3000 posts it to the server, then waits 10000 milliseconds. I have removed both my public and private key from the code as well as my WiFi network info, you'll have to trust me that I actually have them in that actual code.
#include <SPI.h>
#include <SFE_CC3000.h>
#include <SFE_CC3000_Client.h>
#include "DHT.h"
#define CC3000_INT      2   // Needs to be an interrupt pin (D2/D3)
#define CC3000_EN       7   // Can be any digital pin
#define CC3000_CS       10  // Preferred is pin 10 on Uno
#define IP_ADDR_LEN     4   // Length of IP address in bytes
#define DHTPIN 3 //Temp sensor is connected to pin 3
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
WiFi Constants
char ap_ssid[] = "SSID NAME";                // SSID of network
char ap_password[] = "NETWORK PASSWORD";        // Password of network
unsigned int ap_security = WLAN_SEC_WPA2; // Security of network
// ap_security can be any of: WLAN_SEC_UNSEC, WLAN_SEC_WEP,
//  WLAN_SEC_WPA, or WLAN_SEC_WPA2
unsigned int timeout = 30000;             // Milliseconds
char server[] = "data.sparkfun.com";      // Remote host site
// Initialize the CC3000 objects (shield and client):
SFE_CC3000 wifi = SFE_CC3000(CC3000_INT, CC3000_EN, CC3000_CS);
SFE_CC3000_Client client = SFE_CC3000_Client(wifi);
//Set up of server stuff
const String publicKey = "PUBLIC KEY";
const String privateKey = "PRIVATE KEY";
const byte NUM_FIELDS = 3;
const String fieldNames[NUM_FIELDS] = {"humidity", "temp", "uv"};
String fieldData[NUM_FIELDS];
int humidity;
int temp;
int uv;
int UVOUT = A0; //Output from the UV sensor
int REF_3V3 = A1; //3.3V power on the Arduino board for UV sensor
  pinMode(UVOUT, INPUT);
  pinMode(REF_3V3, INPUT);
  // Set Up WiFi:
  setupWiFi();
  Serial.println(F("=========== Ready to Stream ==========="));
  Serial.println(F("Press the button (D3) to send an update"));
  //Start the temp/humidity sensor
  dht.begin();
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  humidity = h; //Assign the humidity reading to h
  temp = t;  //Assign the temp reading to t
  int hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  int hic = dht.computeHeatIndex(t, h, false);
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.print(f);
  Serial.print(" *F\t");
  Serial.print("Heat index: ");
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(" *F");
  int uvLevel = averageAnalogRead(UVOUT);
  int refLevel = averageAnalogRead(REF_3V3);
  //Use the 3.3V power pin as a reference to get a very accurate output value from UV sensor
  float outputVoltage = 3.3 / refLevel * uvLevel;
  float uvIntensity = mapfloat(outputVoltage, 0.99, 2.8, 0.0, 15.0); //Convert the voltage to a UV intensity level
  Serial.print("output: ");
  Serial.print(refLevel);
  Serial.print("ML8511 output: ");
  Serial.print(uvLevel);
  Serial.print(" / ML8511 voltage: ");
  Serial.print(outputVoltage);
  Serial.print(" / UV Intensity (mW/cm^2): ");
  Serial.print(uvIntensity);
  uv = uvIntensity; Assign the uvIntensity reading to uv
  delay(9000); //delay for 9000 miliseconds so that the server is not overwelmed
  // Gather data:
  fieldData[0] = String(humidity);
  fieldData[1] = String(temp);
  fieldData[2] = String(uv);
  Serial.println("Posting!");
  postData(); // the postData() function does all the work,
  // check it out below.
void postData()
  // Make a TCP connection to remote host
  if ( !client.connect(server, 80) )
    // Error: 4 - Could not make a TCP connection
    Serial.println(F("Error: 4"));
  // Post the data! Request should look a little something like:
  // GET /input/publicKey?private_key=privateKey&light=1024&switch=0&time=5201 HTTP/1.1\n
  // Host: data.sparkfun.com\n
  // Connection: close\n
  // \n
  client.print("GET /input/");
  client.print(publicKey);
  client.print("?private_key=");
  client.print(privateKey);
  for (int i = 0; i < NUM_FIELDS; i++)
    client.print("&");
    client.print(fieldNames[i]);
    client.print("=");
    client.print(fieldData[i]);
  client.println(" HTTP/1.1");
  client.print("Host: ");
  client.println(server);
  client.println("Connection: close");
  client.println();
  while (client.connected())
    if ( client.available() )
      char c = client.read();
      Serial.print(c);
void setupWiFi()
  ConnectionInfo connection_info;
  int i;
  // Initialize CC3000 (configure SPI communications)
  if ( wifi.init() )
    Serial.println(F("CC3000 Ready!"));
    // Error: 0 - Something went wrong during CC3000 init!
    Serial.println(F("Error: 0"));
  // Connect using DHCP
  Serial.print(F("Connecting to: "));
  Serial.println(ap_ssid);
  if (!wifi.connect(ap_ssid, ap_security, ap_password, timeout))
    // Error: 1 - Could not connect to AP
    Serial.println(F("Error: 1"));
  // Gather connection details and print IP address
  if ( !wifi.getConnectionInfo(connection_info) )
    // Error: 2 - Could not obtain connection details
    Serial.println(F("Error: 2"));
    Serial.print(F("My IP: "));
    for (i = 0; i < IP_ADDR_LEN; i++)
      Serial.print(connection_info.ip_address[i]);
      if ( i < IP_ADDR_LEN - 1 )
        Serial.print(".");
int averageAnalogRead(int pinToRead)
  byte numberOfReadings = 8;
  unsigned int runningValue = 0;
  for(int x = 0 ; x < numberOfReadings ; x++)
    runningValue += analogRead(pinToRead);
  runningValue /= numberOfReadings;
  return(runningValue);
//The Arduino Map function but for floats
//From: http://forum.arduino.cc/index.php?topic=3922.0
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
