Sketch works on ide but not the web editor?
I've gotten this sketch to work on the IDE but unable to get it working on the web editor. it uploads fine, but keep getting "PH: NO_DATA" in the serial monitor. The module connected via I2C flashes red indicating no communication. Im using mkr 1010 and the module sensor is atlas scientific ph probe and EZO circuit.
  Sketch generated by the Arduino IoT Cloud Thing "pH_Test"
  https://create.arduino.cc/cloud/things/6717560a-59d1-488f-8f50-7565b0301cea
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  float phIOT;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <Ezo_i2c.h>                      // Link: https://github.com/Atlas-Scientific/Ezo_I2c_lib)
#include <Wire.h>                         //include arduinos i2c library
Ezo_board PH = Ezo_board(99, "PH");       //create a PH circuit object, who's address is 99 and name is "PH"
bool reading_request_phase = true;        //selects our phase
uint32_t next_poll_time = 0;              //holds the next time we receive a response, in milliseconds
const unsigned int response_delay = 1000; //how long we wait to receive a response, in milliseconds
  // Initialize serial and wait for port to open:
  Serial.println("begin");
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  Wire.begin();                           //start the I2C
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  // Your code here
  if (reading_request_phase)             //if were in the phase where we ask for a reading
    //send a read command. we use this command instead of PH.send_cmd("R");
    //to let the library know to parse the reading
    PH.send_read_cmd();
    next_poll_time = millis() + response_delay;         //set when the response will arrive
    reading_request_phase = false;                      //switch to the receiving phase
  else                                                //if were in the receiving phase
    if (millis() >= next_poll_time)                    //and its time to get the response
      receive_reading(PH);                              //get the reading from the PH circuit
      reading_request_phase = true;                     //switch back to asking for readings
void receive_reading(Ezo_board &Sensor)                // function to decode the reading after the read command was issued
  Serial.print(Sensor.get_name());  // print the name of the circuit getting the reading
  Serial.print(": ");
  Sensor.receive_read_cmd();                                //get the response data and put it into the [Sensor].reading variable if successful
  switch (Sensor.get_error())                          //switch case based on what the response code is.
    case Ezo_board::SUCCESS:
      Serial.println(Sensor.get_last_received_reading());               //the command was successful, print the reading
    case Ezo_board::FAIL:
      Serial.print("Failed ");                          //means the command has failed.
    case Ezo_board::NOT_READY:
      Serial.print("Pending ");                         //the command has not yet been finished calculating.
    case Ezo_board::NO_DATA:
      Serial.print("No Data ");                         //the sensor has no data to send.
  //phIOT = Sensor.get_last_received_reading();
Hi @nicholasht. I'm going to ask you to post some additional information that might help us to identify the problem.
:red_exclamation_mark: NOTE: These instructions will not solve the problem. They are only intended to gather more information which might provide a clue that eventually leads to a solution.
Please do this:
  1. Select "Preferences" from the menu on the left side of the "Arduino Web Editor" window.
    The preferences panel will open to the right of the menu.
  2. Check the box next to "☐ Always show output panel**" in the preferences panel.
  3. Check the box next to "☐ Console: Show verbose output**" in the preferences panel.
  4. Open your sketch in Arduino Web Editor.
  5. Click the button ("Verify") in the sketch panel.
  6. Wait for the compilation to finish.
  7. Click the icon in the top right corner of the black console panel at the bottom of the "Arduino Web Editor" window that looks like two pieces of paper.
  8. Open a forum reply here by clicking the Reply button.
  9. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  10. Press Ctrl+V.
    This will paste the compilation output into the code block.
  11. Move the cursor outside of the code tags before you add any additional text to your reply.
  12. Click the Reply button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here:
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a forum reply here by clicking the Reply button.
  5. Click the "Upload" icon (Upload icon) on the post composer toolbar:
    A dialog will open.
  6. In the dialog, select the .txt file you saved.
  7. Click the Open button.
  8. Click the Reply button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
Arduino IDE
The process is similar in Arduino IDE. I can provide detailed instructions if that will be helpful to you, but I first need to know which version of Arduino IDE you are using (the process is slightly different in Arduino IDE 2.x than in 1.x).
Thank you for your reply and time, the output is too long to post, and it wont let me upload the file as I am a new user. Shall I post in multiple sections? I have been paying to use arduino IOT for 6 months or so, maybe im considered new user because i haven't posted before? Thanks again
Using IDE version 1.8.13
I apologize for the inconvenience. I should have considered that restriction.
You have now been promoted to "trust level 1" with the forum software. The limitation on attachments should now be lifted. So please try again. Let me know if there are any problems.
Thanks. Here are the instructions for getting the verbose compilation output from Arduino IDE:
  1. Select File > Preferences from the Arduino IDE menus.
  2. Check the box next to "Show verbose output during: ☐ compilation".
  3. Click the OK button.
  4. Select Sketch > Verify/Compile from the Arduino IDE menus.
  5. After the compilation fails you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages. Click that button.
    This copies the full output to the clipboard.
  6. Open a forum reply here by clicking the Reply button.
  7. Click the </> icon on the post composer toolbar.
  8. Press Ctrl+V.
  9. Move the cursor outside of the code tags before you add any additional text to your reply.
  10. Click the Reply button to post the output.
  5. Click the "Upload" icon (image) on the post composer toolbar:
  6. Select the .txt file you saved.
web editor verbose output.txt (248.2 KB)
IDE copy and paste.txt (96.4 KB)
The sketch doesn't fail when compiling on the IDE, so no copy error messages. But I coppied and pasted the text that was there.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\nicho\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\nicho\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\nicho\OneDrive\Documents\Arduino\libraries -fqbn=arduino:samd:mkrwifi1010 -ide-version=10813 -build-path C:\Users\nicho\AppData\Local\Temp\arduino_build_534721 -warnings=none -build-cache C:\Users\nicho\AppData\Local\Temp\arduino_cache_719868 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.CMSIS.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.openocd.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -verbose C:\Users\nicho\OneDrive\Documents\Arduino\i2c_fixed_code\i2c_fixed_code.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\nicho\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\nicho\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\nicho\OneDrive\Documents\Arduino\libraries -fqbn=arduino:samd:mkrwifi1010 -ide-version=10813 -build-path C:\Users\nicho\AppData\Local\Temp\arduino_build_534721 -warnings=none -build-cache C:\Users\nicho\AppData\Local\Temp\arduino_cache_719868 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.CMSIS.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.openocd.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -verbose C:\Users\nicho\OneDrive\Documents\Arduino\i2c_fixed_code\i2c_fixed_code.ino
Using board 'mkrwifi1010' from platform in folder: C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13
Using core 'arduino' from platform in folder: C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13
Detecting libraries used...
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\sketch\\i2c_fixed_code.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Ezo_i2c.h: [Ezo_I2c_lib-master]
ResolveLibrary(Ezo_i2c.h)
  -> candidates: [Ezo_I2c_lib-master]
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\sketch\\i2c_fixed_code.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\sketch\\i2c_fixed_code.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\Ezo_i2c.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\Ezo_i2c_util.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\iot_cmd.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\sequencer1.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\sequencer2.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\sequencer3.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\sequencer4.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire\\Wire.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\sketch\\i2c_fixed_code.ino.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\sketch\\i2c_fixed_code.ino.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\sketch\\i2c_fixed_code.ino.cpp.o"
Compiling libraries...
Compiling library "Ezo_I2c_lib-master"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\Ezo_i2c_util.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\Ezo_i2c_util.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\Ezo_i2c.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\Ezo_i2c.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\iot_cmd.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\iot_cmd.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\sequencer2.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\sequencer2.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\sequencer3.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\sequencer3.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\sequencer1.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\sequencer1.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master\\sequencer4.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\sequencer4.cpp.o"
Compiling library "Wire"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\Ezo_I2c_lib-master" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\Wire\\Wire.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Wire\\Wire.cpp.o"
Compiling core...
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010\\variant.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\variant.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -x assembler-with-cpp -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\pulse_asm.S" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\pulse_asm.S.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\pulse.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\pulse.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\itoa.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\itoa.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\hooks.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\hooks.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\WInterrupts.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\wiring.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\wiring.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\startup.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\startup.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\delay.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\delay.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\cortex_handlers.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\cortex_handlers.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\wiring_analog.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\wiring_digital.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\wiring_private.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\wiring_private.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\wiring_shift.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\USB\\samd21_host.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\USB\\samd21_host.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\compact\\dtostrf.c" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\compact\\dtostrf.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\Reset.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\Reset.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\SERCOM.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\SERCOM.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\new.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\new.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\main.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\main.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\Uart.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\Uart.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\WMath.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\Tone.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\abi.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\abi.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\USB\\CDC.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\USB\\CDC.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\USB\\USBCore.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\USB\\USBCore.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\api\\Common.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\api\\Common.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\api\\IPAddress.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\api\\IPAddress.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\api\\PluggableUSB.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\api\\PluggableUSB.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\api\\Print.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\api\\Print.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\api\\Stream.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\api\\Stream.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino\\api\\String.cpp" -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\api\\String.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\pulse_asm.S.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\USB\\samd21_host.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\WInterrupts.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\compact\\dtostrf.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\cortex_handlers.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\delay.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\hooks.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\itoa.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\pulse.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\startup.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\wiring.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\wiring_analog.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\wiring_digital.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\wiring_private.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\wiring_shift.c.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\Reset.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\SERCOM.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\Tone.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\USB\\CDC.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\USB\\USBCore.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\Uart.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\WMath.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\abi.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\api\\Common.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\api\\IPAddress.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\api\\PluggableUSB.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\api\\Print.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\api\\Stream.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\api\\String.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\main.cpp.o"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\core.a" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\new.cpp.o"
Archiving built core (caching) in: C:\Users\nicho\AppData\Local\Temp\arduino_cache_719868\core\core_arduino_samd_mkrwifi1010_1660ec1e1f707b4cce0161489bef48b6.a
Linking everything together...
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" "-LC:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721/i2c_fixed_code.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721/i2c_fixed_code.ino.elf" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\sketch\\i2c_fixed_code.ino.cpp.o" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\Ezo_i2c.cpp.o" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\Ezo_i2c_util.cpp.o" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\iot_cmd.cpp.o" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\sequencer1.cpp.o" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\sequencer2.cpp.o" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\sequencer3.cpp.o" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Ezo_I2c_lib-master\\sequencer4.cpp.o" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721/core\\core.a" -Wl,--end-group
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721/i2c_fixed_code.ino.elf" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721/i2c_fixed_code.ino.bin"
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721/i2c_fixed_code.ino.elf" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721/i2c_fixed_code.ino.hex"
Using library Ezo_I2c_lib-master in folder: C:\Users\nicho\OneDrive\Documents\Arduino\libraries\Ezo_I2c_lib-master (legacy)
Using library Wire at version 1.0 in folder: C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_534721/i2c_fixed_code.ino.elf"
Sketch uses 31032 bytes (11%) of program storage space. Maximum is 262144 bytes.
Global variables use 3956 bytes (12%) of dynamic memory, leaving 28812 bytes for local variables. Maximum is 32768 bytes.
Oops. Sorry about that. I picked the wrong version of the instructions. Great job on figuring out the correct way to get the output despite my fumbling.
The list of libraries and the memory usage summaries shown in the output from Arduino Web Editor and Arduino IDE are dramatically different. Are you sure you compiled the same sketch in each of them?
hey i've just compiled the exact same sketch into web editor and it does work
#include <Ezo_i2c.h>                   // Link: https://github.com/Atlas-Scientific/Ezo_I2c_lib)
#include <Wire.h>                         //include arduinos i2c library
Ezo_board PH = Ezo_board(99, "PH");       //create a PH circuit object, who's address is 99 and name is "PH"
bool reading_request_phase = true;        //selects our phase
float phIOT;
uint32_t next_poll_time = 0;              //holds the next time we receive a response, in milliseconds
const unsigned int response_delay = 1000; //how long we wait to receive a response, in milliseconds
  Wire.begin();                           //start the I2C
  Serial.begin(9600);                     //start the serial communication to the computer at baud rate of 9600
  if (reading_request_phase)             //if were in the phase where we ask for a reading
    //send a read command. we use this command instead of PH.send_cmd("R");
    //to let the library know to parse the reading
    PH.send_read_cmd();
    next_poll_time = millis() + response_delay;         //set when the response will arrive
    reading_request_phase = false;                      //switch to the receiving phase
  else                                                //if were in the receiving phase
    if (millis() >= next_poll_time)                    //and its time to get the response
      receive_reading(PH);                              //get the reading from the PH circuit
      reading_request_phase = true;                     //switch back to asking for readings
void receive_reading(Ezo_board &Sensor)                // function to decode the reading after the read command was issued
  Serial.print(Sensor.get_name());  // print the name of the circuit getting the reading
  Serial.print(": ");
  Sensor.receive_read_cmd();                                //get the response data and put it into the [Sensor].reading variable if successful
  switch (Sensor.get_error())                          //switch case based on what the response code is.
    case Ezo_board::SUCCESS:
      Serial.println(Sensor.get_last_received_reading());               //the command was successful, print the reading
      phIOT = Sensor.get_last_received_reading();
    case Ezo_board::FAIL:
      Serial.print("Failed ");                          //means the command has failed.
    case Ezo_board::NOT_READY:
      Serial.print("Pending ");                         //the command has not yet been finished calculating.
    case Ezo_board::NO_DATA:
      Serial.print("No Data ");                         //the sensor has no data to send.
  Serial.print("float ph: ");
  Serial.println(phIOT);
is there a tutorial to turn this into an IOT cloud sketch? Its my understanding that i need to add this to the sketch and change the phIOT variable from the offline sketch to an IOT variable in the things tab.
  Sketch generated by the Arduino IoT Cloud Thing "Untitled 2"
  https://create.arduino.cc/cloud/things/09b3bf40-6003-4c5d-8b74-ec7c808a687c
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  float phIOT;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  // Your code here
  Since PhIOT is READ_WRITE variable, onPhIOTChange() is
  executed every time a new value is received from IoT Cloud.
void onPhIOTChange()  {
  // Add your code here to act upon PhIOT change
this is the updated sketch;
  Sketch generated by the Arduino IoT Cloud Thing "pH_Test"
  https://create.arduino.cc/cloud/things/6717560a-59d1-488f-8f50-7565b0301cea
  float phIOT;
  Serial.println("begin ya cunt");
  delay(1500);
  initProperties();
     Maximum is 4
  // Your code here
    PH.send_read_cmd();
  Serial.print(": ");
I still get no data and red flashing light indicating no communication, i've included the verbose otput from the updated sketch as a text document.
ph iot verbose output.txt (1.5 MB)
I'm glad it is working now.
I don't know of a tutorial specifically about this, but there is a lot of information about Arduino IoT Cloud here:
https://docs.arduino.cc/arduino-cloud/
My advice is to start with the simple "Cloud Blink" template:
https://create.arduino.cc/iot/templates/cloud-blink
This will make sure basic communication between the Arduino IoT Dashboard and the Thing device is working as expected.
After that, you might look at some of the other templates to see if one does something similar to what you want to do with your real project. You could use it as a reference, or even modify its code as needed:
What happens if you upload THE SAME SKETCH to your board using Arduino IDE instead of Arduino Web Editor? Do you get different results?
thanks again for the infomation. I am quite familar with the iot cloud and have made multiple working projects (although this is the first using an I2C device). I usually do it in the IDE and copy it over using the same method. but for some reason this project just wont do what I expected.
The same sketch works in the IDE and also the web editor before i add the IOT variable and the generated code to connect to IOT cloud and wifi.
And what about after?
heres sketch i tried compiling
#include "arduino_secrets.h"
  float phIOT;
  Serial.println("begin");
  delay(1500);
  initProperties();
     Maximum is 4
  // Your code here
    PH.send_read_cmd();
  Serial.print(": ");
  Serial.print("ph float: ");
here is the error message
Arduino: 1.8.13 (Windows 10), Board: "Arduino MKR WiFi 1010"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\nicho\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\nicho\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\nicho\OneDrive\Documents\Arduino\libraries -fqbn=arduino:samd:mkrwifi1010 -vid-pid=0000_0000 -ide-version=10813 -build-path C:\Users\nicho\AppData\Local\Temp\arduino_build_298556 -warnings=none -build-cache C:\Users\nicho\AppData\Local\Temp\arduino_cache_99405 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.CMSIS.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.openocd.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -verbose C:\Users\nicho\OneDrive\Documents\Arduino\pH_Test_oct08a\pH_Test_oct08a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\nicho\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\nicho\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\nicho\OneDrive\Documents\Arduino\libraries -fqbn=arduino:samd:mkrwifi1010 -vid-pid=0000_0000 -ide-version=10813 -build-path C:\Users\nicho\AppData\Local\Temp\arduino_build_298556 -warnings=none -build-cache C:\Users\nicho\AppData\Local\Temp\arduino_cache_99405 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.CMSIS.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.openocd.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -verbose C:\Users\nicho\OneDrive\Documents\Arduino\pH_Test_oct08a\pH_Test_oct08a.ino
Using board 'mkrwifi1010' from platform in folder: C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13
Using core 'arduino' from platform in folder: C:\Users\nicho\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13
Detecting libraries used...
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_298556\\sketch\\pH_Test_oct08a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for ArduinoIoTCloud.h: [ArduinoIoTCloud-master@1.7.0]
ResolveLibrary(ArduinoIoTCloud.h)
  -> candidates: [ArduinoIoTCloud-master@1.7.0]
"C:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\nicho\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\nicho\\OneDrive\\Documents\\Arduino\\libraries\\ArduinoIoTCloud-master\\src" "C:\\Users\\nicho\\AppData\\Local\\Temp\\arduino_build_298556\\sketch\\pH_Test_oct08a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Arduino_ConnectionHandler.h: []
ResolveLibrary(Arduino_ConnectionHandler.h)a\Local\Temp\arduino_build_298556\sketch\thingProperties.h:3:0,
  -> candidates: []
                 from C:\Users\nicho\OneDrive\Documents\Arduino\pH_Test_oct08a\pH_Test_oct08a.ino:17:
C:\Users\nicho\OneDrive\Documents\Arduino\libraries\ArduinoIoTCloud-master\src/ArduinoIoTCloud.h:27:10: fatal error: Arduino_ConnectionHandler.h: No such file or directory
 #include <Arduino_ConnectionHandler.h>
compilation terminated.
Using library ArduinoIoTCloud-master at version 1.7.0 in folder: C:\Users\nicho\OneDrive\Documents\Arduino\libraries\ArduinoIoTCloud-master
exit status 1
Error compiling for board Arduino MKR WiFi 1010.
This means you must install the "Arduino_ConnectionHandler" library. You can learn how to do that here:
hey I've installed all neccessary libaries and successfully uploaded but im still having the same issue.
IOT on IDE verbose.txt (160.2 KB)
By "same issue", do you mean "Sketch works on ide but not the web editor"?
no communication between the devices. serial print reads "no data" and the red flashing light on the ezo board which indicates "command not understood" according to the manufacturers datasheet. the sketch succesfully uploads
OK, so you are not having the same issue. The subject of this topic is your claim that a sketch worked in Arduino IDE but not in Arduino Web Editor. In the end, we found that the different results were caused by using two different sketches, not by using two different development tools.
So this topic is concluded. Please open a new topic to ask for help with the bug in your sketch.
Okay, thank you for your time and help!
You are welcome. I'm glad if I was able to be of assistance.
Best wishes for success with your project.
Per
